Hello, My name is Adam and I'm an alcoholic...( battery wiring advice ;)
    Hello.
    my name is adam...and im an alcoholic. ;) LOL
    actually, i was looking for advice on installing ebike batteries.
    I purchased a 500w 36v real wheel hub ebike with controller and thumb throttle.
    i found some xioami scooter batteries and bird scooter batteries on the street corner and plugged them into charge.
    they work perfectly so i thought id use them for my ebike. but when i plug them up and give throttle the motor doesnt spin.
    the lcd display turns on and power bars show that the batteries are good. but im not sure why it wont work?
    is the BMS for the scooter batteries the reason why the batteries wont respond to the ebike controller?
    if so is there a simple way to fix this problem as i dont have extra funds to buy new batteries them are very expensive.
    I noticed that most batteries on ebay for example just have blue plastic around them and various different plugs. can i just remove the BMS
    from the scooter batteries and simply solder the battery direct to the charging plug and then just plug and play or something equally simple?
    thank you for your help, adam
