New guy here.
Before I order a BBS02 for my wife's Terratrike Maverick, I have questions I have not been able to find answers for. If you can help, please let me know:
- Can the Bafang display DPC-07 (default display with the package I am considering) support the 20" wheels on my wife's Terratrike? I will be ordering a programming cable with the package, but I have been told the display supports only 26" and larger wheels.
- Do other displays support 20" wheels?
- I plan to use a 52V battery. Can the DPC-09 be calibrated for a 52V battery or will the indicated battery level be wrong. If wrong, a lot wrong or only 1-(48/52) wrong?
- For mounting on a recumbent trike, I will need cable extensions. I plan to solder custom length cables for the speed sensor/gear sensor/brakes /battery cables? I hoped to save cost, avoid loops of excess cable, and reduce the number of potential connection point failures by soldering my own. Is this a bad idea?
- Her Terratrike came stock with a single 170mm 38 tooth chainring (and 12-32t 8speed microshift cog). The stock Bafang BBS02 will have a 46 tooth chainring, so I expect she will be giving up torque for higher top end. Can the motor handle the 39lb trike, 20 lb? motor and battery, and a 115lb rider or should I replace the 46 with a 38tooth chainring? She will be using the trike primarily on dirt roads, with minimal trail riding. I'm not looking for more speed, but I also don't want to tax the motor too much.
Thanks for your thoughts.
