Hi There I am new here I have a E- Bike with DMHC 36v Display with the Bafang motor made in china . Until recently the bike was working fine then i noticed that pedal assist mode would not engage and on the display module it doesnt display the battery level even after fully charging the battery it also doesnt display the system currents/voltage , also if i apply the throttle it doesnt display how much throttle is being applied, has this happened to anyone else ? and if so were you able to work out which module is failing ? for example the display module or maybe the system control module ? is there a diagnosis function or error code display ? it would be greatly appreciated if you are able to help me to resolve this issue
pedal assist failing so is display of battery + throttle or currents
