I installed a ignition key switch on ONYX RCR to the KELLY CONTROLLER KLS7230S , I want to by pass the alarm from turning off the bike. Right now i have the switch connector to the power wire that turn on and off bike from the alarm. Could I install a toggle switch to the power wire from the controller to the alarm to turn off the alarm? is the power wire from the controller to the alarm 12V ? and connect I use that wire to my key switch to turn on and off the bike?
wiring help!
I had never heard of any of those components or that sort of mod before and I suspect many of the other members of this forum are in the same boat as me so all we would be doing is google on the topic which I assume you already tried. A large number of the active members here are using products Luna sells or has sold like Bafang mid drives and SurRon bikes. If you have a question on those I'm pretty sure you would get an answer.
Originally posted by jimsond View Postthanks for all your help!!!!!!!!
https://endless-sphere.com/forums/vi...bf5a863d26f65e
