Calling Luna . . . Ready to Order BBSHD kit & Battery - Need Questions Answered First
    I'd like to put a BBSHD on a new Boris FS X9 I just received from Bikes Direct. I asked these questions in my introduction post and am hoping to get a response here. I really want to order the BBSHD and battery as soon as possible, but before I place an order, I have some questions:
    1) As for the display, it looks like the C965A with the 3 button switch is being shown on Luna's website for the C965 option. Is the 5 button C965 not available? I have the C965 5-button on my other bike and I like the ability to toggle between km/hr and mph. Is the C965 with the 5 button pad gone for good?
    2) How about the Satiator charger? It has been shown as "Out of Stock" for a while now. No longer available at all? Backordered? expected back in stock when? What's the story? It seems like a superb piece of gear.
    3) The following photo is a close up of the frame triangle with dimensions. I would like to order a battery pack and bag if they will fit. I have the "shark" type battery case on my other bike and I'm a little leery about the robustness of the bracket attaching to the bottle cage bosses. Can someone confirm whether the Luna triangle bag will fit inside my frame triangle (not truly a triangle as the curve in the top tube makes it sort of a mutant triangle)?
    I made a cardboard template of various battery packs from Luna and it looks like I might be able to fit the new 30q 48V 21 ah brick inside the frame, but maybe not once it's surrounded by a triangle bag. May have to default back to the shark package option. Sure would be nice if someone could confirm the battery packaging options for this frame. I know that Karl likes his batteries on his back, but I would rather not lug the weight around if I happen to stop somewhere en route while riding.
    4) It looks like the connector type for the battery power leads are different depending on battery selection. The 30q says it has the XT90 connectors with a mating connector for the controller thrown in. The power leads for the shark batteries are pictured as bare pigtails. The description for the BBSHD kit says plug and play. So, does Luna attach all appropriate connectors to the wires before shipping the kit to the customer if battery and motor kit are ordered together? Are all necessary connectors included and installed or are some customer installed? Not trying to be difficult, but I want to avoid placing an order and then getting part way through the installation and find out I need to order additional or different parts or have to perform some soldering I wasn't anticipating
    5) In the connector section of the website, there is a 3-pin bulkhead connector shown labeled as a j1772 with male pins and a hinged cover. Does this mate with the XLR connectors shown next to it as a 5 piece set? The description doesn't mention what size wire the solder pins at the rear of the connector will handle. Nor do the pictures show a manufacturer brand. I have a possible application for this connector, but need to have both mates and know the maximum wire size that will fit the solder cups of the pins. If a maximum DC current spec is available, that would be good to know also.
    As the title and my opening paragraph state, I am ready and anxious to place an order with Luna, but I'd like these questions answered by someone from Luna. PrettyPlease???
    I dunno, I like the 3 button. It's a nice display. All the to do about 5 button, when the three works just fine. All due respect to Karl, I copy and use his ideas often, there other good working options. Your plan to use templates is the best course. All builds require some give and take. After all we're adapting to already configured frames. Build a full cardboard mock up. Make a template of the interior triangle. I'd love to say a pack will absolutely work, but that would be foolish. Making a recommendation and missing a detail would make for an unhappy buyer. Shipping batteries around is expensive, and sometimes not possible, at least not legally following current regs. No vendor wants a customer coming back and saying they need to take a pack back cuz you said it would fit. I hope you can understand that. Every time I do a build I find niggling details peculiar to that frame and gear. 100's if not thousands of details among equally as many frames and configurations. My latest build was planned around the pack I wanted rather than trying to figure out what would fit. But I still ended up with details to sort. That's just the nature of the beast.
    It takes some research and planning to sort a really clean build. Sometimes regardless of the planning we end up taking a course contrary to the original plan. For me that's part of the fun. The option is a gutless, ready built, poor fitting, overpriced off the shelf, creation costing twice as much. Sometimes I just end up looking for another frame with a more workable geometry. My first choice a couple of years back was a bomb. I just didn't think it out and insisted on being stubborn. Nothing's changed, I still have to sometimes make changes midstream.
    For me I decided I ought to sort how to solder and manage connectors. I learned with a $14 kit. I used to add a couple of connectors to every battery order I made.. Eventually every builder will need to solder and replace a connector, or join a wire,why not just learn right out of the gate? Being self sufficient really is liberating. I no longer even think about connectors or sweat the detail. Actually Eric convinced me to give up on connectors when using batteries that have brackets. the battery can be removed making connectors unnecessary. Even if the vendor you buy from has really nice matching connectors they're gonna be on the end of to much wire. They do it to cover a wide range of builds. Now, you have a to long coil of wire to figure out where to hide or deal with. Cut the darn wires back to the minimum and solder the shortened wires. No connectors to deal with, no coils to hide and mess up the build. Best lesson ever for me. I say solder, for the best build, and gain the skill you'll eventually need if you going to continue. What happens when the throttl you need is 5 days away, you want to ride, there's a throttle at the local shop but the wrong connector? No problem, cut the connector and a length of wire off the bad throttle, solder, heat shrink and ride today! Freedom! eBike style.
    Googling connectors I found a pretty good piece on eBikes.ca. But these days the first hit is our own electricbike.com. https://www.electricbike.com/ebike-connectors/
    Sometimes it's just not possible to get everything from one shop. Inventory comes and goes. Relationships change, like every build there's all sorts of reasons and changing details. For me that's just the nature of the beast.
      Yeah,
      I second the sentiment about overcoming any fear about connectors and accepting the idea of mastering some modest soldering ability.
      Otherwise, I just looked at those two Shark battery box (48v & 52v) dimension diagrams. And they seem to be the elegant solution, to me, as an out-of-the-box battery for that frame. I'm not saying it will necessarily be a perfect fit, though. But, the shape and color is ideal for that frame, in my opinion. But I'm not a fan of nylon bags for battery packs.
      Of course, I'd go with the 52v one at 13.5 Ah. And later you may be able to come up with a modified mounting solution or make it even more stout somehow and fitting it right down into the lowest area by just drilling a couple of alternative holes on that 13.25" mounting base plate, even though I don't necessarily like that removable aspect of the battery. Personally, I've become a fan of using two-piece collars around bike tubes as mounting solutions, though. And, your first eBike battery will undoubtedly not be you last or only one, in all likelihood.
      That 52v Shark pack with its stealthy battery box, upgraded to the 13.5 Ah, with mounting hardware, and an added advanced charger is a nice value at under $600.
      I think most people here do or will eventually adopt a pioneering spirit and take some risks with a decision like yours. And some of those kind of decisions I've made haven't worked out perfectly, but often can still be helpful later, like in when I order a new battery, I'll go ahead and get a charger to go with it, even though I didn't need it. So, I have back-ups and some redundancy in chargers. Ha, ha, ha...
      So, please let us all see what you decide on and how it works for your application. Then you can be a resident expert on that particular combination. Click image for larger version
      • Louis
        Louis commented
        It's the narrowing of the top tube and down tube that concerns me. Unfortunately, being a big dolphin fan and not having installed the Shark pack I'm gun shy. I have one on the way to build out my own pack, but haven't had my hands on one yet. Do you think it will slide off the bracket on the referenced frame? If it fit it's a nice look, as you point out, on that frame. My newest frame was chosen based on the triangle measurement knowing my Dolphins and frame packs will definitely fit. Also the reason I skipped the Motobecane frame. I have drilled out a couple of frames to move the bracket to a better fitting position. That has worked out well for me. No downside that I can see. Other than being a bit nervous the first time.
      • Christian Livingstone
        Christian Livingstone commented
        Right,
        That slide-out mechanism could be problematic in some installations. I mean, I've never personally used one, but I believe I've seen them mounted with the tapered end pointed in both the upward and downward direction, which seems like battery removal wouldn't be a problem as its mounting could just be flipped if it does become one. AND, is it not possible to charge those batteries while mounted?
        I mean, those Shark batteries and their mounting style may be the best of all worlds, so to speak, in that a smaller and cheaper battery can be mounted. Then, if if more range is desired, another small and cheaper one could be packed for the journey. And that has the added benefit of redundancy, so that if one battery becomes faulty, the other is ready to fill in.
        So, yeah, I think I like that better than the idea of getting one, big, expensive, heavy battery.
        I mean, I run two 12.5Ah 52v batteries with two BMC hub motors on an eTrike, and I like the redundancy, as sometimes I can feel one of the batteries hit the low voltage out-off when the packs are low, but I don't lose power, and the other battery and motor comes on again, as I just don't accelerate as hard at those times.
      Take a look at the c10 display which is a 5 button and is now an option on the BBSHD http://lunacycle.com/parts/bafang-pa...isplay-dp-c10/ I believe it is only 30 dollars when you add it to the kit.
      Although our triangle bag will probably fit in that frame it will be crunched and might not look right.
      Please please let us know if you mount a shark pack or dolphin pack into this frame and how it does fit...i was looking into getting one of these frames myself.
        Gee,
        There's a new thread that has some pics of what may be an example of this same fitment, and it does look like a squeeze.
        Or, maybe that's the Dolphin pack that's shoehorned in this photo. The Shark packs seem to be sleeker.
        http://electricbike.com/forum/forum/...000-trail-bike
          Lesabret,
          This may be obvious, but I'll mention it anyway, as it was a pitfall for me in my research. Keep in mind that frames for a particular model vary in size. If you see a frame like above that barely fits a pack, you will want to know if it is an XL or a Small sized frame. Often folks don't mention the frame size used in build threads.
          It's nice to see that your thread questions generated some thoughtful and encouraging feedback, even though you didn't receive exactly the confirmation you were asking for. Don't be discouraged. I understand why a seller can't confirm fit for you on a frame they haven't used before. Providing dimensions for a template is about the best they can do, and the dimensions provided by Luna should be enough for a builder to make a paper model to test fit. As you did already, great!
          My Luna Triangle bag will compress to less than 1/4" thickness where it is padded around the perimeter, if that helps. It is not super thick. But you need to leave some room for it. And, if the shape of the bag's perimeter is too deformed, zipping it will be probably be tricky, and it may not keep the battery located very precisely. As Eric noted already, it probably won't look great if fitted into too small a frame. The triangle bag has a great shape when stretched out, keeping the sides taught. If compressed, with saggy, wrinkly sides, not so much. My Medium sized Motobecaine Sturgis is on the small end of what I think can work well for their 20 Ah triangle bag. Your frame looks to be significantly smaller than mine, and would distort the shape more.
          Now, use some judgement about what you saw when test fitting that cardboard model...if there is less than about 1/4 clearance all around, I'd be worried. More than that, and I bet you could mount it effectively. Even less, if you are creative. Perhaps not with the Triangle bag, but with some other method. Soft sided lunch box and zip ties? Custom Cordura bag made at a local upholstery shop? Custom box made by you and mounted to the frame bosses or with velcro straps? That's the hard, but fun, part of planning a DIY bike project. Research, plan, rethink, research some more, until you create a design that you are happy with and proud of. Having a frame and a selection of packs to choose from is the foundation, now see what you can make of them.
          But, in this DIY ream, responsibility lies with the builder to make the call about what components to use. The frame dimensions and photo you shared are certainly helpful, but are really not enough to fully define the frame geometry (angles not defined, photo distorted by angle to camera) for anybody to confirm fit of a given pack. But the battery drawing above is pretty clear, as are most of the dimensioned drawings for other packs at Luna. I think making a full scale paper (or cardboard) model of the packs which interest you is a good enough tool to let you do the rest. Picking a components to fit your project is a necessary part of creating a unique build you will be proud of. And you wind up with a cooler, higher-value bike than you could buy ready-made. If that's what you are after.
          Here are just a couple links to example DIY battery mounting solutions as examples. I don't know your skills, but if you can work with wood, fiberglass, fabric, plastics, or sheet metal, or have a buddy/relative who can, you should be able to come up with a mounting plan for any battery that will reasonably fit your frame, even if the intended mounting system won't work for you. Heck, I bet you could make a functional battery case with paper mache' skills learned in grade school, with some waterproofing.:eek:
          Crude and Simple: http://www.energeticambiente.it/real...diy-mkiii.html
          Fancy and Difficult: https://endless-sphere.com/forums/viewtopic.php?t=23290
          Some have even done handlebar mounted packs, or rear rack mounted packs. Both options degrade the handling of the bike compared to mounting the heavy battery low and central in the frame, but maybe these are acceptable trade-offs for your project?
          Best of luck, and don't give up. None of this is as easy as clicking 'order me this ready built bike now for $x,xxx', but it's a heck of a lot more rewarding.
          Edit: you can do 'lost foam' fiberglass or epoxy parts without much experience, and wind up with a pretty nice enclosure. You basically make a foam model of the shape you want, then put resin and fiberglass over it, then dissolve out the foam. Then cut an access port and make a cover. I've done this process several times for various complex-shaped parts. It's messy and requires some time, but you get a strong part in exactly the shape you want. Remember to leave a little room for the thickness of the layup (glass+resin) when you are done. I use West Systems epoxy, which I get at my local boat shop. Auto parts stores have a polyester resin that can work and is cheaper, but it's smelly, hard to measure, and can set up real fast. Here's a link to some info from the West Systems site, you can find a ton more online: http://www.westsystem.com/ss/the-los...e-fabrication/
          If you want to try something like that, I'd be willing to give some more specific suggestions. It would probably cost you upwards of $100 in materials to go the epoxy route, as you would probably need to buy a quart of resin and a pint of hardner, roughly. But you would have quite a bit left over, and it is super handy stuff to have around. Keep that in mind for comparison if you get a $150 quote for a custom bag; the ready made bag option might not sound too bad.
          Edit 2: If you do get quotes for custom upholstery work (make a bag to your spec), you should get several quotes, in person. I recently got 2 quotes for a custom motorcycle seat cover in the $400-500 range at automotive shops, then got a $90 quote from a place that sells foam, fabric, and does old furniture repairs. They did great work.
          Edit 3: Actually, since you are in Michigan (I don't know where), maybe you can use the same place. I think they could do it. That shop that made my seat is: Foam N' More & Upholstery, Inc on Maple in Clawson, Mi.
            Originally posted by Christian Livingstone View Post
            Gee,
            [ATTACH=CONFIG]n1816[/ATTACH]
            Thats funny thats my old bike...it was the first bafang prototype BBSHD bike and i got it from Bafang at innerbike and traded it for another bike later.
            I remember thinking a shark was a way better fit for that bike...both the dolphin and the shark fit. The dolphin the battery is not able to slide on or off so it has to be creatively mounted to the frame.
            I think the Shark will slide on and off....but i never got the chance to actually try it.
              Yeah,
              A Shark pack will undoubtedly (when I say undoubtedly, I'm not pronouncing a fact, of course) be a great match for that Motobecane frame shape and color. Sure, the plastic mounting base of the Shark pack is not as robust as the aluminum base of the Dolphin ones. But maybe it won't ever become a problem, and even it it does, I'm guessing there's more that one good remedy that doesn't take too much fuss.
                I have done about 4 bikes with the shark style battery and almost always had to drill a 5mm hole in the aluminum part of the battery mount plate to get it where I want it on the frame. Bolting through the aluminum part of the shark mount into the waterbottle mount is more secure than the plastic part of the shark mount. Occasionally, I add rivnuts to the frame. Some people are afraid of rivnuts but if you use zinc plated steel they are super strong, they don't weaken the frame - in fact the circular expanded force in an aluminum frame actually makes it stronger and they are fairly easy to put in. Those two things give you a lot more options for mounting the shark battery pack on the frame. Keeps the weight centered and low where you want it. You can even add one or two more Rivnuts if you are worried about how secure 2 are. Here is a picture of one I just did with 2 rivnuts. One through the aluminum part of the battery mount plate. I put the rivnuts at normal water bottle spacing in case I ever convert it back. Note the location. No room in the triangle due to full suspension. Plenty of clearance for the front wheel but need to watch big logs and rocks. :)
                Do something that is good for your health, good for your wallet and good for the planet - get an e-bike.
                www.poweredride.com
                  Hey,
                  Nice info and clean execution on that groovy frame. That front fork is wild.
                    Yeah, Cannondale Lefty's are real head turners - and conversation starters. They have a few benefits like stiffness, travel and the ability to change a tire without taking the wheel off. :) I didn't think this Cannondale Prophet was a candidate for a mid-drive with a frame mounted shark until I figured out the rivnuts and extra hole in the shark aluminum mount. I wanted to keep it sexy. Frame bags are functional but definitely not sexy IMHO. A frame bag probably wouldn't have worked on this anyway and a seatpost rack mount was too iffy. So, it was either this or a backpack and I don't like biking with a backpack.
                    www.poweredride.com
                      I was in a bike shop today and saw a bike with an elastomer front and rear suspension. The front forks had an elastomer bushing/bumper with some sort of polycentric action.
                      I thought the bike was new and cutting edge somehow, but the bike shop owner told me it was a Pro Flex bike from the mid-1990s and that the bike was ahead of its time.
                      Interestingly, the actual bike owner newer rode it in all that time, and wanted it refurbished with new elastomer bushings and tires so that he could sell it. I was told the guy was somehow embarrassed by how much he paid for the thing originally, which was around $2500.
                      I've always like the idea of a bike frame that has the chainstay/swingarm tubes up and away from the chain, so it can't clang around. And the aluminum whe
                      It looked like this one, only like brand new and with new tires that were two-tone black and red, which surprisingly matched the frame color well.
                      I think it'd be cool to see one of those unpainted, with just a brushed aluminum finish.
                        I was back it that same bike shop today and snapped a phone/photo of that un-used, 20 year old Pro Flex bike.
                          Original poster here:
                          working on bike again after hiatus.
                          I ordered and received the BBSHD kit and a shark 52V pack back in March. I modified the mounting plate to allow the shark package to fit the downtube and then the bike sat undisturbed for a few months until today.
                          Today I started to disassemble the bike to prepare it for the motor installation. Removed the front derailleur and chain and then went to work on the crankset and bottom bracket. The cranks came off without a hitch and the left side bottom bracket cartridge retainer nut came off with only a slight assist from a deadweight mallet on the breaker bar.
                          Another tap on the spline of the cartridge and the assembly moved out the opposite side of the frame and I pulled the crank, bracket and chain ring all in one piece out from the frame.
                          NEED A LITTLE HELP HERE . . . . Moving over to the right side of the frame. I put the socket and breaker bar on the retaining nut, but couldn't get it to budge. Tried lefty loosey first, then tried righty loosey with no luck.
                          Didn't want to force the nut in the wrong direction so here I am at a standstill needing and requesting some guidance from anyone out there who has the same bottom bracket setup as what is on this Boris FS X9.
                          The Bikes Direct website spec sheet for the bike lists the bottom bracket as a "SRAM GXP100 100x 1.37 BSA standard English Threaded"
                          If I can get the correct direction to rotate the socket, then I can feel better about adding some muscle to the breaker bar.
                          Thanks in advance for any help offered. I'm eager to keep this project moving forward.
                            I took this photo. This is the standard 68mm threaded bottom bracket. Hope this helps
