I hav been testing parallel battery setups with my hub motor. Everything good and safe and stable. I get consistent more power for longer and a bit more torque.
my question is this 2 40A BMS 52 V 19.2 AH BATTERIES
would this mean I can setup controller to draw 80A without overwhelming the bms in each battery since it will draw 40 and 40 or will I still be limited to the per battery max bmsbut it’s still splits for example set controller for 40A max and it will use 20 and 20.
also is this the same for wattage as both batteries ideal output ration is 200-2000watts. Would that mean that combined the draw can be up to 4000w.
asking this questions I don’t want my ludi to ruin my batteries would like to setup settings on ludi well.
thanks in advance
thanks in advance
