I have a Mars M3 ebike similar to the Jetson Adventure it uses a Luishi controller with 8 pin connector for a 1T4 harness but I have 1T3 which is minus throttle connector. It’s all in the downtube even if I could pull out the controller the harness is well laced and organized in factory.
I know that the gear sensor brake sensor 3 pin headlight and throttle can connect on the same connector but I have 2 yellow 3 pin male brake sensors and a green female 5 pin display and no, what would be a 3 pin female plug for throttle.
Is it possible to y splitter one of the male brake sensors to a throttle even if it's male vs female plug? This means the throttle connector would still be a female plug and the thumb throttle male which is what I originally needed. Are all 3 pin signals to the 8 pin connector the same even if the throttle connector was originally missing?
