Hello out there!
okay so I have a question I have a 700c bike with a bbs02motor and a 52 volt battery I currently have a 48 tooth stock sprocket and I use the bike to commute now this is the second motor that I put on because the first one fried melted the internal gears Within 22 days of purchasing it so I'm on my second BBs02 motor now.I used Mobil Grease 28 on the secondary gear in hopes of better lubrication anyway I want to know if it would be a good idea to put a 42 tooth Bling Ring On It or a 46 tooth Bling Ring I don't want to lose top speed but I also don't want to turn up the internal gears on this one I do notice the motor is really hot by the time I get to my work which is about a eight mile commute with mostly flat roads! I usually max out at about 32 miles per hour in the highest assist level and the smallest rear cassette gear.so does anyone have any recommendations they can give me on this topic? it would be appreciated thanks for reading and get back to me ! and one more thing does anyone know why Bafang made the motor with nylon internal gears instead of just making them all metal?
