Can you fit 7.6mm wide zip ties through the grommets on the triangle frame bag?
2X TURNIGY Multistar High Capacity 10000mAh 6S 22.2VHello, I have very little experience with these lipo batteries.. I am going to power a 1000w 48v hub motor. What is the best/ safest way to wire these? If I wire them in series I will get 44,4 volt nominell so that will be to little right? does these have bms integrated in them? Wich type of charger should I use to charge them? I want to do this safest possible so I cant manage to overcharge them or undercharge.. I know that the constant discharge is 10c andthe peak for 10seconds is 20c. Is that something I need to think about when I am riding? do I need to disasemble the packs to fit a BMS so I dont have to think about discharging them to much?
What do I need to not do anything wrong? I know in lithium batteries that the BMS take care of those problems.. is it the same case with these lipo`s?
Thanks
Much Appriciated
MagnusLast edited by bearing340; 07-08-2018, 06:14 AM.
Originally posted by bearing340 View Post2X TURNIGY Multistar High Capacity 10000mAh 6S 22.2VHello, I have very little experience with these lipo batteries.. I am going to power a 1000w 48v hub motor. What is the best/ safest way to wire these? If I wire them in series I will get 44,4 volt nominell so that will be to little right? does these have bms integrated in them? Wich type of charger should I use to charge them? I want to do this safest possible so I cant manage to overcharge them or undercharge.. I know that the constant discharge is 10c andthe peak for 10seconds is 20c. Is that something I need to think about when I am riding? do I need to disasemble the packs to fit a BMS so I dont have to think about discharging them to much?
Thanks
Much Appriciated
Magnus
All nut sizes have a standardized coarse and fine thread pitch. All of the hub motor axles that I have seen are the coarse thread pitch.
You can probably also assume that it is metric. I have seen M14, M15 and M16. Make sure not to use SAE nuts!Last edited by commuter ebikes; 07-10-2018, 06:50 AM.
This page has printable to-scale charts which can be used to ID anything
https://www.boltdepot.com/fastener-i...s/default.aspx
For the 750W hub motor will any of your other twist throttle options work with the included controller. Specifically looking at the thin profile one as it will not interfere with my shifter.Last edited by Edq1; 07-09-2018, 08:19 AM.
If you're referring to the BBSxx twist throttles, then unfortunately no, since they're only compatible with BBSxx mid-drives only.
Do you know what the difference is? I have a BBS kit I got last fall and it came with what appears to be the same half throttle that came with the hub motor kit. That makes me think the controllers are looking for the same input from the throttle.
Summarizing:
New battery won't charge.
New BBSHD Kit with:
TRIANGLE 52v Panasonic GA 18650 24ah Pack HIGH POWER + LONG RANGE52-TRI-24-GA
300 Watt Advanced Charger
When I plugged in the charger for the first time, it showed 58.8V, green LED is on, no fan activity. I doubt the battery was shipped fully charged. The little voltmeter shipped with the battery shows something like 48V with the charger unplugged and 58.8V with the charger plugged in. The DPC-18 shows 60% battery.
I've tried various sequences of powering the charger and connecting to the battery, waiting 30 seconds each time, and leaving connected for several hours. Also various Amp and % rates on charger. Same result.
Lightbulb test method, using 53 watt bulb, pulling 0.27 Amps1 Photo
Hi Luna,
I'm interested in the Bafang BBSHD: https://lunacycle.com/bafang-bbshd-1000w-middrive-kit/
- Currently, it's on sale for $679.00, how long is the sale going on for?
- I'm planning on installing it on a Yeti SB6c 2015, do you have a record of any customer installing on that bike?
- Most likely, the battery will be mounted under the downtube, do you guys have brackets for that?
- On your website, you mention that a smaller selection of chainring for the BBSHD is available, but I don't see the selection (other than the 46T Chainring)
- If in an unfortunate case, and I can't mount the BBSHD for some reason, can I return it?
- My bike 's(Yeti SB6c) bottom bracket is a PF92, is it compatible?
Thanks,Last edited by icestix; 07-09-2018, 02:35 PM.
If you are sitting on the bike, the flange of the pressfit adapter will be on your left.
No the kit does not with either bsb adapter those are sold separately. Most people do not need them, but most people are not using pressfit adapters either.
Here is an example https://lunacycle.com/bsb-1-stabiliz...s02-and-bbshd/ there is also a version for full suspension with some significant design differences, that's the bsbf-1.
Yes the chart was made a long time ago. I went ahead and updated it.
I just checked the bike's frame, and I noticed these notches at the bottom of the BB (https://media.alltricks.com/hd/56ea8153ca7ab.jpg). I'll have to get the measurements to see the gap between the notches, but does it means that I can't mount the BBSHD?
I would be more concerned with the chainstay than the extra bits on the bb shell. Those bits can be cut off with an angle grinder easily, but not much can be done about an intrusive chainstay.
TBH might be easier to just buy a random used hardtail MTB off Craigslist and start with that. Not saying this is impossible but it is certainly more involved. Might even mean getting a 120mm and multiple spacer kits so the secondary reduction housing is not touching the chainstay
hey Luna i was just wondering because i don't see an indicator for the cutoff brakes on DCP-18 display is there an option i can turn on to be able to see when the motor cuts off? The reason I ask is because i'm going hydraulic and it would be helpful to see the indicator on the display itself so i can epoxy the cut-off switch to the brake levers. I know it's a small thing but was wondering if the DCP-18 has that option.
Thanks
I bought a solid state switch from Lunacycle (https://lunacycle.com/remote-on-off-solid-state-switch/) that worked perfectly for a long time. Then I swapped out my battery pack (same voltage, new cells) and rewired everything with no shorts or anything. Now the LED on my power switch won't light up, but the switch still works for switching on/off. Did the 12v on the Lunacycle switch somehow break?
Would shutting off the hub motor at red lights and on again after i get going add extra heat to my already streesed out cheaper hub motor?
Not only would this fail to cool the motor faster, doing this is a hazard because you would not have the power on tap to make a quick escape from a dangerous situation.
Ferrofluid would be a very economical solution that would make a huge difference https://lunacycle.com/luna-ferroflui...-coolant-10ml/.
My motor shutting off has been a problem today it happened after only 2 blocks, the motor was not hot tho just the controler, could that be a cause of a over heating problem? Yes yes it will, especially when it is starting to melt the motor wires. The next morning my motor is still giving troubles i wonder if I'm jist pushing the weight limit too much. Perhaps i should buy American made motorsLast edited by Weht; 07-12-2018, 07:49 AM.
Hi -- order #56303.
Quick question is to confirm that I do need the custom tool to install the BBSHD?
Then, as more of a suggestion -- it is quite confusing when items simply appear and disappear from your website, rather than being listed as "temporarily out of stock". I first looked at your site quite a few weeks ago, checking out the BBS02, and saw the option to add the custom tool. A week or so later, I checked out the BBS HD, and saw no option for a tool. I figured this meant the HD didn't need a tool. I suppose I should have become suspicious when the 73mm HD simply disappeared from the HD page, but in the several weeks that I waited for it to come back, I still never saw a tool option.
Yes, the install Tool is required to tighten the locknuts into the bottom bracket.
unless you have a wrench that can tighten the locknut of the bbshd you will want to use the tool... if you don't know what it is you definitelly need it...
...and I'll add that the $20 tool will do if you insist, but you really should buy the torque wrench with sockets. My first BBS02 install with the hand wrench loosened several times, so I said forget that jazz on my first BBSHD and spent the money. The torque handle has the values for locknut and cover etched in, and the sockets are gorgeous. Don't even think about faking it, spend the money!
How do I slow down the motor?
I've mated a BBS02 750w to Haul-a-Day Bike Friday cargo bike which has 20" wheels. I have the single 48T sprocket chainring and the Luna DPC-10 display and a 52V Shark 13.5a battery. My problem is that the motor turns to fast at pedal assist level 1 on flat straightaways. I would like the motor to assist less. I have gone into the settings and adjusted the wheel diameter all the way down to 16", which reduced the assist slightly...but it is still too fast. Is there a way I can detune, or slowdown the motor at pedal assist level 1? I do have a programming cable, however I have not attempted to use it yet, as I'm not sure what I would adjust. Any advice is much appreciated. - Anthony
Yes you can, you will need a program wire and some tweeing to do, You can reduce the power and rpm for each PAS level.
This will help you out : https://electricbike.com/forum/forum...shd-mid-drives
And this to get programming tips: https://electricbike.com/forum/forum...hd-programming
