Thanks and I’ll try that today when I get home. If the swiping does not work what would be the next step? This morning I noticed the light on the sensors was dimly lit. I turned the power to the unit on and the light went off completely. Just wanted to see if that might be a bigger problem? Thanks!
Bought a BBSHD setup a month ago and the charger is dead. Plug it in and nothing happens. It’s the Luna 48v advanced charger. Trying find how to check the fuse, but the online documentation links are either broken or lead to manuals for old chargers. Any thoughts?
If it's DOA and the display doesn't even light up when plugged in take a pic and send it to support@lunacycle.com along with your order number for replacement.
Hi,
My daughter and I built up a BBSHD luna kit using a Rocky Mountain Element mountain bike for her to ride to school. We got a 52v Panasonic Shark Pack 13.5ah GA and Luna Charger 52V Advanced 300W Ebike Charger. It took us a while, but the build went smoothly, and the bike rocks. It seems to work great EXCEPT the range is considerably less than what others have posted and we were expecting. Riding in PAS mode, she's getting about 9 miles of range from the 100% charged battery in relatively flat terrain. The two times she's tried riding the 6.8 miles to school and back, it's died on her with 4-5 miles to go. I noticed the charge voltage stopped at 54.6v. Since then, I tried doing several cycles of partial drain, charge at 1 amp, then leave overnight to let balance and repeat. I've been through 4 of these cycles, and 6 charges of the battery total. The voltage at full charge has gone up to 55.7v, but hasn't exceeded that the last 2 charges. I've read on the forums that a 52v battery should charge to 58v, and I think the relatively low charge voltage we are seeing relates to the low range. I'm not sure how to proceed with getting more range from the pack. It seems from others with the same pack that it should charge to a higher voltage and have greater range. Any ideas? BTW, I'm looking at the voltage reading on the Luna Charger, which reports slightly higher than the color display.
Thanks,
Jeff
Hello, ive purchased a 68mm cyclone 3000w kit and now want to put it on a fatbike. Could someone please give me a list of parts I'll need to buy for it to fit 100-120mm fatbike and a link please? Thank you
If you already have everything you needed to do it with 68 then you probably just need the larger bottom bracket. There's several available so you will want to measure the BB shell on the fattie and see what size you need, then order it off the cyclone parts section.
Note: if you go with an isis bb instead of standard square taper, and the original was square taper, then you need isis cranks as well. So just keep in mind that whatever bb you are using needs a matching crank
Trying to build my first Ebike. From Luna, I have the monster cyclone and just ordered the 72v 100amp battery. I know that the battery does not come with a charger. Luna customer service recommended that I use this charger= https://www.amazon.com/Charger-Li-io...SoDb9iL&preST= . The problem is that I need a different charging plug for this charger to plug into the battery. Does anyone know of a charger that requires NO mods? If not, please help me find the charging adapter/mod required for this amazon charger to work with the 72v 100amp battery.
Thank you paxtana. Is it known when the Luna charger will be available? If I were to purchase the amazon charger, how would I know when the battery is charged? (It has no voltage screen, unlike the Luna charger).
You'd wanna use a multi-meter to manually check it. Chargers will be re-stocked in a few weeks or less.
I am a little confused about the best way to gauge battery use. I have a 52 volt battery tht will charge up to 58v, which is obviously 100%. I was riding to day on about 44v and the battery gave out. The battery icon display did indicate it was very low. If my goal is to charge to 80% and use to 20%, do I pay attention to a voltage meter or the display icon? Is 44v near to 0%? By the way I commute up a 1.5 mile hill at average 7% grade. I am trying to gauge how taxing on the battery this is. Any tips?
You want to go off the voltage. The battery gauges are all made for 48v and not accurate for 52.
44 on a 52 is like 10% at resting voltage. If you pull a lot of power at that low state of charge it's going to sag the voltage considerably, and make you hit low voltage cutoff. LVC for BBSxx is around 42, for the pack itself is a bit lower.
Here is a chart you can refer to. May want to print it out for reference.
Hey Luna Cycles! A quick question for bbshd.... So I have a Race Face 30t Narrow wide crank and a SRAM PG1130, 11-42t, 11-speed back, its a diamondback mason 2. What would you guys recommend as a chain ring? Luna BBSHD 130BCD Chainring Adapter?
Luna BBSHD 130bcd Spider Chainring Adapter?
Luna Eclipse Chain Ring for the BBSHD 42 T?
Luna Mighty-Mini 30 tooth BBSHD Chain Ring?
I want to avoid terrible chain line, and also have good torque and top end.
If the eclipse 42t is a possibility, would I have to change chain length?
TIA
ChrisLast edited by ChrisJTX; 09-08-2018, 04:17 PM.
Chainline depends on the frame, and the width of the rear hub, and whether you have an intrusive chainstay etc. We can't just flat out say for one frame or another, frames change all the time. That said, if you start with the stock ring you'll get a good idea how much further inbound you can go without hitting the chainstay. Or just go with the 42t eclipse and back it off with chainring spacers if need be. Any lower than 42t can't wrap around secondary and will not give good chainline. Using chainring adapter will not wrap around chainline either. Only Eclipse and Lekkie 42t or higher will do that.
I am looking to buy this set up
BAFANG ULTRA MAGNESIUM MOTOR Ebike Mid Drive
Edit Remove
1 × $749.95
TRIANGLE 52v Panasonic GA 18650 28ah Pack GIANT RANGE + HIGH POWER 52v Mini 3amp Advanced Charger with 3 Position Toggle $55.00
Edit Remove
1 × $1,054.95
My question is, will this set up work on a medium 2018 Kona Wozo. ? I want this battery to fit in the frame. Really excited about the idea of having a 1456wh fat bike !!
Nope.
That bike is a standard bicycle. Ultra needs a purpose built frame requiring access to a skilled welder. We have several mid drives that may work but this is not one of them.
Additionally, the chainstay appears to be flaring out fairly intrusively from the bb shell so even a standard mid drive may need spaced out.
As to the battery there are dimensions pics on the listing, make a cardboard mock-up and see if it fits. Not possible to tell you if a battery will fit a frame just going off a picture, especially on one of the largest batteries in production. I had a guess I would say it is unlikely to fit especially taking into consideration clearance issues to mount the bag.
How about the Bafang 1000 Mid drive kit working with the Kona wozo? It looks like that one slides right into the crank case.
You'll wanna check these links to see if it'll fit. There are like a gajillion different bikes out there that nobody could possibly know the compatibility of them all unfortunately.
How to order the right Bafang BBS02 or BBSHD the First Time ! Many folks ask the question "Will a BBSHD fit my (insert any bike here)?" . The simple answer is usually "Who knows?" . There are too many variables involved for Luna or the electric-bike forum users to give a definitive answer. The only time
If you are planning to build a mid-drive BBSxx series bike, then the first piece of information you need is what size and type bottom bracket shell you have. Full article on choosing a BBSxx kit here (http://electricbike.com/forum/forum/kits/bafang-mid-drives/10736-how-to-order-the-right-bbsxx-kit) The Bafang BBSxx series of
https://www.reddit.com/r/ebikes/wiki/bbs_faq (comprehensive list of tools needed here, very helpful)
The main thing you should know though is if your bottom bracket shell has threads on the inside, It pretty much means your style of bottom bracket will likely take the BBS motor without needing an adaptor. Threaded bottom bracket shells are called JIS or BSA standard and this is what the Bafang motor kit was designed to work with. The inside diameter of your JIS-BSA shell should be 33.8mm +/- .2mm. Check it. Twice.
I had 8 dead cells in my battery, and I was able to replace them with new cells using a spot welder. I forgot to charge the new cells, so now they read 3.5V while the other cells are 4.0V. Will the new cells ever get balanced from drain and recharge, or do i need to independently charge just these cells to get them up to the same voltage as the other cells?
Don't know where else to look for a similar configuration.
Folding 20in wheels, 52t chainring, 16t single speed stock. I weigh about 210-220lbs. Want to save by using BBS02 (48v), but concerned for it's reliability/durability.
Goal is to keep the reliability up, and weight & cost down. I drive truck, and this will sit in belted in the jump seat. Tried a MPv5 on another build, was too cumbersome, but learned some. Going for a mid for weight, fun, sight-seeing, etc.
Plan on eventually getting an IGH? Recommend 3 or 8spd? Would like to keep the same amount of chain teeth if I can help it? Should I bite the bullet for the BBSHD, though might be overkill? Seeking recommendations.
Thank you for your time.
Guys, any experience with dual front chain-rings using either of these:
Looking for a 40/52T with a reasonably ok chain line on a BBSHD.
Thanks
Kindly answer:
1) Does Luna have the Bafang Ultra 1000 in Stock?
2) If yes, please confirm Luna will support me with parts if I buy one? I have read on the internet nobody is selling parts on these and I want to buy one, but only if I can be assured of spare parts availability.
1) https://lunacycle.com/bafang-ultra-m...ike-mid-drive/
2) Sorry, are you looking to buy the motor or the internal parts to it? The motor kit is for sale but we do not sell the internal parts right now unless it's under warranty. This is still a very newly released motor. It may take a couple years for spare parts to flood the market.
Thanks but please answer:
1) Is the drive in stock or will you order it when I order it?
2) Do you STOCK warranty parts for this drive or do you just order them from Bafang when my drive has trouble??
3) What about AFTER the warranty period? Will you sell me parts then if I buy the drive from you now?
1) It is in stock. Our stock system is tied to the website so typically if you can add it to your cart. It means it's available to order.
2) We likely have some in stock but only reserved for warranty purposes.
3) If it's outside of warranty, we might be able to make an exception if the part is needed such as a stripped Nylon Gear or something, but we cannot sell them on their own unless otherwise.
