I need to charge 8 replacement battery cells that are already spot-welded into my battery. They have a voltage of 3.5V, while the other cell groups have 4.0V. I can "cut-out" the 8 cells and charge them independently as a group of 8 by just cutting the nickel strips. Should I just wire the charger +/- to the 8 cell group and monitor the voltage carefully? I don't know how else to charge them since I am not easily able to separate each cell to charge in a typical AA charger. Or, should I just purchase brand new cells at this point. There does not seem to be any way to get the cells to balance as part of the full grid in my 48V bike battery.
So, the only solution is to buy new cells, charge them individuallly, and then replace them in the battery pack. No amount of charging and discharging of the battery pack will balance the cells, even if I bypass the BMS wiring.
I assume I need to use a stardard battery charger for the individual cells, and can not charge of group of 8 cells that have already been spot-welded together? Ideally, I could just disconnect the group of 8 cells from the main battery by cutting the nickel plate, charge them as a group, then redo the nickel plate. Otherwise, I’ll need to purchase 8 brand new cells and do a lot of work to rebuild the entire battery.
Hypothetically there might be a possibility that the BMS will balance it. There is no industry standard for the threshold for the BMS to refuse to balance, but that does seem like a pretty large imbalance so I wouldn't be surprised if it refuses to do so. I guess there's no harm in giving it a shot though as the alternative is quite more difficult
I'm trying to build a mid drive, non pedal assist bike. I want to add a cog to the left side of the real wheel so I can run the motor without losing normal pedal functionality. Does anyone know how I can attach a secondary cog to the rear? Or any advice on other ways to set it up?
Thanks,
Silas
Good to know. I'm planning on using a Turnigy Aerodrive SK3 Brushless. Where would I run the belt or chain to if I were to do this? I think the issue I'm running into is that I want to have a mid drive, and also have a normal drivetrain.
Sorry, this thread is for support questions regarding products sold by Luna.. That said, I would still answer it if I knew the answer but I do not.
You may want to start a new thread in the new builder questions section, perhaps someone there may have more info.
What you need is somewhere here. https://custommotoredbicycles.com/
I have just received a new Luna advances charger 48v 300W. Looking at video from Luna there are some discrepences. Only one led light, No visible place for fuse replacement. I have used the charger on my 48v 14amp hour battery. The charger did its job an charging the battery but then began a cycle of going on and off. I am having no luck finding any definitive in formation. How do I replace a fuse on this unite? What is the cycling about. Possibly trying to top of or balance the cells?? There in absolutely no information regarding this in the manual sent with this unite. FRUSTRATING!!! Respectfully Submitted.
First off thank you for the reply. I suspect that my issue is a common one but have not been able to get a definitive answer. I used the lunar adapter for the 5.5 barrel adapter from Luna. I was very carefull to make sure that I connected brown wire which is positive and the blue wire that is negative. I also used the shrink wrap that came with the adapter. All connections very solid. My battery had been charged to full using the 2 amp adapter that came with it. About 2 weeks had passed since doing this. When I plugged in the Luna charger it initially showed a red light and proceeded to charge the battery. After 4-5 minutes it then began to cycle on and off showing the red light and then the blue light also the fan cycled on and off. I am hoping that the device was in some sort of balancing mode or top off. After a short time I turned of the luna charger not knowing if I was damaging it. If possible any input would be most appreciated. Thanks HighVoltage.
HIGHVOLTAGE, After reading all the links that you sent me I found what my problem was. The ebike folks that I bought my bike from advised to allways plug in the barrel connector before powering up the charger. Following the advice from one of the links you sent me fixed everything. Battery charges right up light turned green and it no longer cycles on and off. It is peop[le like you who take the time to respond it guys like me that make a forum the valuable repository of knowledge it is. But I am sure others had the answear besides you. It is guys like you who take the time to help that should be recognized for that and are truelly are the real asset to this group. Thank you guy!!!!!!
No worries. Just all in days work lol. Glad you got it figured out though. :)
After searching around on Lunacycle and anywhere else, I can't find a cradle for the Killer Whale battery. Is there a way to special order just the cradle? https://lunacycle.com/48v-panasonic-...ck-huge-range/
- Likes 1
I'd like to buy a number of things from Luna. I'd like the 3KW Cyclone kit, a Bluetooth controller, and the $120 cyclone mount. Just about everything is out of stock. What's going on? Any idea when these things will be back in stock? Thanks.
Generally speaking re-stock questions should go here:
If luna is out of a product you would like to see restocked or know when it will be available again.... name the item here if possible with a link.
But the answer to your question is basically a few weeks or so. We literally "just" ran out of stock for these items. So you gotta give us sometime to re-order and ship them to our location so we can start sending them out. Considering Cyclone is located in Taiwan. It usually takes some time.
Originally posted by Steve View PostI have a 2015 KHS 4Season 3000 fat bike. Will the Mighty Mini 30T chainring provide a good enough chainline with the BBSHD 120mm? Also, does that chainring still come in Black?
Sebz is the guru for answers, but my experience was not so good with the 30 tooth and had to use the 42 to get a good chainline on my 3000. I wore out the 30 in a couple of weeks of riding everyday. I think your 2015 has cable pull disc brakes and may not be the same as my later model with hydraulic brakes.
xcnick, True the 2015 is a little different but maybe since he has 190mm dropouts it should be similar to the 2017 and up... I have no chain problem on my 3000, I've run a 30T mini, Lekkie 36T and 40T and still on my original cassette (only have like 500 miles of trails and snow riding tho)
Thanks guys, I think I'll give it a go with the 30T Mighty Mini and see what happens. The following link is to my exact bike, so I do have hydraulic brakes (not sure if that would effect the chainline unless some of these came with 197mm dropouts). https://khsbicycles.com/bikes/2015-k...eason-3000-15/
Good afternoon!
Planning to order a mid drive bafang kit for my bike
Choose a memorable domain name. Professional, friendly customer support. Start using your domain right away.
Can you please advise me which one between the bbshd and the bbs2 will fit without any technical problems or modifications?
Thanks in advance!
Hello
Usually we cannot make any 100% confirmations of these kits working with every bike including cable lengths & BB measurements, We currently do not ship these motors with any direct instructions since there are so many different bike variations and standards. It's kind more of a "DIY" type deal where you have to learn as you go. All bikes are different and therefore we always suggest to base your build off a previous documented build from our forums instead if you want to a easy to follow instructions with guidelines.
This post is to put all the bbshd and bbs02 bikes with documented build threads in one place. For full suspension bikes with a Shark battery pack see this post here. (http://electricbike.com/forum/forum/builds/ebike-building-directions/14686-a-list-of-full-suspension-bikes-that-a-shark-pack-will-fit-on-the-downtube-pictorial)
That being said, Here below is some really helpful links that you can use to decide if you think your bike is BBSxx compatible. Generally if you can meet the requirements for it and your bike is fairly standard in design and size, the installation should require minimal skillsets.
How to order the right Bafang BBS02 or BBSHD the First Time ! Many folks ask the question "Will a BBSHD fit my (insert any bike here)?" . The simple answer is usually "Who knows?" . There are too many variables involved for Luna or the electric-bike forum users to give a definitive answer. The only time
If you are planning to build a mid-drive BBSxx series bike, then the first piece of information you need is what size and type bottom bracket shell you have. Full article on choosing a BBSxx kit here (http://electricbike.com/forum/forum/kits/bafang-mid-drives/10736-how-to-order-the-right-bbsxx-kit) The Bafang BBSxx series of
The main thing you need to know is if your bottom bracket shell has threads on the inside, It pretty much means your style of bottom bracket will likely take the BBS motor without needing an adaptor. Threaded bottom bracket shells are called JIS or BSA standard and this is what the Bafang motor kit was designed to work with. The inside diameter of your JIS-BSA shell should be 33.8mm +/- .2mm. Check it. Twice.
If you're interested in choosing a different chainring with the BBSxx kit, you'll definitely want to take a look at our offset information guide on our forums. Since they all have different offsets, some are only best with proper spacing and a straight chainline. It's usually best to just go with the Default 46T Steel Ring or 42T Lekkie Bling ring for the most reliable setup until you've judged what your chainline looks like first and what kind of potential spacing you can use for smaller or larger rings.
Because of the presence of the motor taking up space, the point where a chainring would mount onto the motor is pushed out to the right from where a chainring would normally be. Offset is defined as how much distance you are able to bring the sprocket closer towards the frame. This results in a better chainline, less likelihood
Here's an example of a bad chainline using our Mighty Mini 30T improperly, This chainring is known to be the most problematic without proper spacing due to it's completely flat design that doesn't offset the chain at all:
My Luna Advanced charger is only rarely charging my Luna Shark pack to 58.8V. Most of the time it charges to 54-55v and then shuts off. Sometimes when it does this the green light just dims; other times it goes red.
It does seem like it's more likely to get back up to 58.8v when I discharge it below 48v and to be less likely to get back there when only discharged to, say, 51 or 52v. But this isn't absolute.
Bad charger, or bad battery?
How old is it? Has it always done this?
Charger and battery were both purchased in April, started using them in early May.
It's been doing this since July or so.
These days when plugged in to the wall with no battery connected and a green light it reads somewhere between 53-55v almost all the time. Sometimes as high as 56v, maybe once every three weeks 58.8. This is independent of what the 80/90/100 switch is set to and it changes over time (was at 53 when I started typing this and is at 54v now).
I've tried multiple 2.5mm adapters, same behavior.
Plugging in a battery just now, it shows 54.6v and a dim green light. Fan's off, Amp display is 0.00Last edited by Hari Seldon; 09-13-2018, 11:58 AM.
email support@lunacycle.com with your order # and pictures of the charger.
