    How much faster do you want to go over 20 MPH?
      Right now, I'd be happy with 30mph. More interested in how it will do with the weight of two riders
      Wondering if I could buy a cable and test the outputs somehow??? Or connect it to a display?
        Hello, I am installing a BBSHD kit (order #70082) on a 68mm bottom bracket Fuji mountain bike. After seeing the quality of the provided crank arms I decided to invest in some Lekkie buzz bars. First I bought your 170mm left offset arms, not realizing that there were other options. The left offset made the left pedal stick out 18mm more than the right one (the originated flat crank arms were perfectly centered around the frame based on caliper measurements between the crank arm ends and the center tube). I just returned those to get the Lekkie flat crank arms. I tested the flat Lekkie crank arms today, which are centered nicely in the frame, but the left arm interferes with the motor casing by around 3mm. Do you have any suggestions for resolving this issue? I'd really like to keep the crank arms centered, and I think the cheap Chinese crank arms look terrible. I was wondering if you would suggest getting a 100mm bottom bracket rotor. I think that would lead to other problems though. Thanks in advance!
        Before I buy another rotor can someone let me know why the gear on the rotor has snaped twice now. I just replaced the motor stator. Took it out and a half block and it snapped. And no it wasn't bogged down it was in an appropriate gear. I hear people say its built like a tank but I have had more than my share of problems with it since I bought it 9 months ago. The first time I probably had it for 3 or 4 months and then just a few hours ago.
          This is not really something anyone can answer for you here. If it was purchased recently from Luna, email support@lunacycle.com and they should be able to help you out. Personally I've rode mine hard for two years and never experienced this problem.
        A bad batch perhaps? See https://electricbike.com/forum/forum...ent-bbshd-part
          Hello guys! I finally got a new rear derailleur, went out to ride and realized the pedal fails to engage from time to time, and sometimes slips as well. Thats the best way I could describe it. Im attaching a video so you can see what I mean. Also, when under more stress something seems to make a popping noise. Im hopig I can get some help in this and find a way to repair it. Thanks!
            The slipping is coming from your chain skipping over the cassette/freewheel most likely. Common issue. Check your chainline and you might need to change your chainring out if you're using the default ring.
            You can test for this by taking off the chain from the motor and running the motor to see if it makes any funny noises, but usually speaking it's the chain and the cassette that is having issues.
          • ordnaj3la
            ordnaj3la commented
            Gotcha, thanks! As for the pedal? It seems its an internal problem, im thinking it could be the clutch?
            If you think it's the clutch, you can open it up and check on it. Should be easily replaceable
            This tutorial is to do maintenance on the BBSHD<br><br> You better don't take any chances and order a paper gasket they break very easily, Click here. (https://lunacycle.com/parts/bafang-parts/bbshd-parts/gasket-for-main-steel-gear-bbshd/) <br><br> Tools needed:<br> You will need a small blade
          Does the 3kw emotor kit come with the chain tensioner as see in the picture, but I don't see it in the what comes in the box
            You mean the tensioner in this pic? Yes it should be there. If not email support.
            I do believe I need a new BMS for a Mighty Mini purchased May 2017. Does Luna have this BMS?
            BMS PN: L-963-14S/30A-1192 21703070017
            Pack PN 52-MINI-6-30Q
            Symptom: Zero current (not a single mA) into the charge port with measured 59V at the charger
            Jump Started by charging through the discharge port. Current flows in and out of the discharge port. No change at charge port.
            Pulled the sensor wire plug, waited for 1 minute, reconnected: Same issue at charge port. Had to jump start to get current in and out of the discharge port.
            No signs of any burning or bad solder joints in pack.
            Original problem with this pack wasn't no-charge. It lost about half its capacity, seemingly overnight.
            It's possible the BMS doesn't like the low values at B1 and B5. I don't know what it will tolerate before shutting down the charge port. Pack charges fine through the discharge port, without any noticeable cell heating.
            Cell Voltages:
            B- B1 3.99
            B1-B2 4.19
            B2-B3 4.19
            B3-B4 4.23
            B4-B5 4.08
            B5-B6 4.24
            B6-B7 4.24
            B7-B8 4.24
            B8-B9 4.24
            B9-B10 4.10
            B10-B11 4.22
            B11-B12 4.22
            B12-B13 4.23
            B13-B14 4.23
            Does Luna offer an upgraded controller for the 1000w hub motor kits?
              Sorry, we do not :(
            Looking for some hydraulic Disc Brake Sensors for my Rad Power Bike RadWagon, happen to know if Rad bikes uses either one of these connectors?
            thanks,
              I would ask Rad Power instead. Don't have any experience with the Rad Power bikes. Looks like they use a Bafang Hub motor but hard to say on the connections they use.
            I have a 20s battery pack that I'm using with an ASI BAC800. I'm looking for a good on/off switch or keyed ignition (preferred). Any ideas?
              So this ebike has a (36V 11.6AH) Battery with a 500W Hub motor (I believe its a bafang), If I switch it out with your (52V 6AH) Mighty Mini. What difference can I expect? What controller should I purchase with it?
              The controller on this looks just like your "Replacement Controller for Hub Motors" except the cable to the hub motor is different. Is there a wiring diagram I could use that might be compatible with whats already on the bike?
                You'll see an increase in top speed heavily and a bit of a decrease in range
                However for the controller question. you'll wanna check with the original manufacture of the Hub Motor. You can't really just swap controllers around from other kits though without some heavy knowledge of the motor and some advanced skillsets
                You would be better off just starting over with a donor bike from Craigslist and a BBSHD/BBS02 kit than to try and upgrade a generic bike you already have.
              If it is a Bafang Hub, would that controller work? What else do I need to know before purchasing those two items?
                Bafang makes more ebike components than any other company in the world, with many variations on said products. We can provide no assurance that any controller made for bafang (or any other company for that matter except the one it is sold for) would be compatible, it just does not work like that. Also the controller you mentioned was not made by or for bafang, and it is sold out..
