What will be the weight rating (maximum load weight) of the X-1 Enduro FS EBIKE?
Hello
Have a question about the BBSHD
Pedaling the bike works fine.
When throttle is engaged motor makes whirring sound and does not turn pedals.
(motor turns on and spins)
& can't move bike backwards,chain is locked.
this was preceded by a loud vibration through the cranks.
Do you know what this could be??
Regards,
Robert
Wait, why would the motor turn your pedals when the throttle engaged? That would be dangerous. Do you mean that you can't pedal? You might've broken the clutch.
I'd open it up and look https://electricbike.com/forum/forum...e-and-greasing
BBSHD whirring,but not turning pedals. (preceded by much vibration through cranks) Pedaling the bike works fine.
Just found this Youtube for a broken shaft. https://www.youtube.com/watch?v=JQs9eWvM-pQ
Thanks,
Robert
Suggestion: auto-assist level
I bought a stealth fixed bike to ride just to get out and get some exercise. I live in a very hilly area and need some help mostly on the hills. I think it would be great if the assist level could automatically increase as the incline increases. Especially given that the stealth has such a small battery capacity.
Since I am biking for excercise I don't real need/want a boost on downhill. Maybe only level 1 on flats, and 2-3 on inclines.Last edited by dpcook; 06-22-2019, 09:12 AM.
I need an extension cable for me gear sensor.
You have this cable which works, but I need 1-2 inches, not 40. The extension I need is so short even a barrel extension connector might work.
https://lunacycle.com/bafang-gear-se...tension-cable/
Is it easy to splice and shorten this cable? Or is it gelled; stranded cable, or otherwise impossible to shorten?
Originally posted by pc500 View PostI need an extension cable for me gear sensor.
I'm looking for a e-bike for some assist when riding with my boyfriend (he is an avid cyclist, I am in average shape). The last e-bike I tried had too much assist even at the lowest setting, so that I either zoomed ahead on level 1 or fell behind on zero assist.
I really like the Luna stealth fixed; what's the approximate power output on each of the settings? Thank you.
Hi, My BBSHD was making a whirring sound,but not turning the chainring. I took it apart. Clutch looked and felt ok. Center shaft not broken. Took off Nylon Gear cover and it lookes like its Broken. Problem solved.
If I only knew where to get a Nylon gear to replace it. Can't seem to find one anywhere.
Thanks,it just took the courage to take the motor apart,not a huge undertaking at all. just a new skill learned.
Robert
Might have to ask Luna when it will be back in stock but ... https://lunacycle.com/bafang-bbshd-n...eduction-gear/
A couple X1 questions. Max speed for the standard config w/ throttle? Also, I understand throttle is not included with the ludicrous controller to avoid damaging the motor in ludicrouse mode, but what about non-ludicrous modes with the ludicrous controller? Will it work with throttle? Or will the ludicrous controller disable throttle for all screwdriver settings?
Max speed is probably dependent to some extent on how much you are pedaling. With throttle only it should be equivalent to other 48v mid drives since voltage is the primary factor to top speed, not amps. Maybe around 28.
Throttle is not on the ludi mode, yes. I do not know what you are referring to with non ludi modes and ludi.
I found a Nylon Gear Here: https://www.ebay.com/itm/BAFANG-New-...r=472519423569
I chose them because the fast shipping,(and Luna was out of stock.
I ride my Ebike to work 6-12 miles a day,and lots of hills. Without it,I have been having to take Uber to work,and it's adding up.
Cheaper than car insurance an repair in the long run though.
Thanks for all the Support people,keep you "posted" on the results.
Cheers,
Robert
Throttle is not on the ludi mode, yes. I do not know what you are referring to with non ludi modes and ludi.Last edited by tomdav; 06-23-2019, 10:31 AM.
I recently installed a Bafang BBS02 Mid Drive on a Gary Fisher mountain bike. All was going really well until I was going up a hill and the motor seemed to be not engaging. I fully charged my battery. The display works, but anytime i petal or hit the manual throttle all i hear is the motor whining, but it does not engage the crank. NO POWER. bummer, have barely used it a week. Please help!!!
