I was riding today and noticed in PAS1 and PAS2, while pedaling up to speed, little momentary loses off power. I've noticed it a few other times too but wasn't sure if It was just in my head, so I watched the watts on the display and it WAS definitely dropping from 250w - 300w to basically 0w for a couple pedal revolutions then quickly back to powered. It did this a few times although seemed to "snap out of it" if I immediately switched to PAS 3,4 or 5 and really got going. Throttle controls the motor normally if I hit it while this is happening. I have a BBSHD w/ 80 miles on it. I bought it 3 months ago from Luna. It has their hot rod settings, the only settings I played with was the amps, from 30a to 25a for a quick ride then to 28a. Other than noticing this, the motor has run incredibly, this build is my first ebike and it's totally blown my mind how sweet it is. I just hoped this, um, "chugging" I geuss i'd call it, at the really slow speeds was sometimes normal. Any input would be much appreciated,thx
the speed limit in each PAS level is set to 100%
