I oil my chain by suspending the bike in my shop from the seat, and goosing the throttle while i slobber the chain lube on. Been doing that way for years, but just recently, I noticed a new noise, ONLY with no load, with the wheel suspended. Riding, it's as quiet as ever. I read up on the lube procedure, but only did the right side, using Mobile 28, with no difference being made. BBSHD, about 2500 miles. I know the noise issue has been beat to death, but I am unclear as to whether or not it matters if it only happens with no load on it. My next move is to run it up with the big ring gear off, to see if it still makes the same noise. I didn't know about that trick until doing some searching here. I've never messed with the left side, where I understand the plastic gear is, and I STILL don't see the logic of greasing a plastic gear.
On the battery. I have seen reccomendations to wait after charging before driving. My solar keeps my battery charged continuously.
I guess my question is the surface charge is higher after initially being charged. (Surface charge is not yet absorbed) than it is a half hour later. Running off the surface charge does not seem to be a problem?
sorry for this probably unimportant probable inconsequential non issue. OCD.
Are you referring to the voltage fresh off the charge? Lithium batteries do tend to sag after you stop the charge, especially if they have some cycles on them. Probably also if there is power keeping it at 100% constantly since that's a little rough for lithium cells to stay at 4.2v like that.
Anything you are doing to pull your battery back down into the ideal band of %SOC as soon as possible is going to have more pros than cons. That said, how soon you pull power from a fully charged battery is not nearly as important as what you are charging to (assuming you are trying to maximize cycles rather than maximizing range for that particular trip)
Will the PF41 adapter work with my 2019 Trek Farley 5? It currently has a Race Face x91 41mm BB.
Sounds like it may.
If you are planning to build a mid-drive BBSxx series bike, then the first piece of information you need is what size and type bottom bracket shell you have. Full article on choosing a BBSxx kit here (http://electricbike.com/forum/forum/kits/bafang-mid-drives/10736-how-to-order-the-right-bbsxx-kit) The Bafang BBSxx series of
I ordered the Sur-Ron Super Moto Conversion Kit but upon closer evaluation I noticed that the inside of the hub is slightly off center. I haven't tried putting the axle in yet but it seems like it would be near impossible unless the hub shifts back into place if the axle is jammed in. Is this normal?
Sorry if this has been discussed before but I didn't find info after searching the forum for while.
Can I swap out the stock Sur-Ron fork for a Fox 40 27.5" fork that has a straight (non-tapered) 1 1/8" steer tube?
Also wondering what hub spacing is needed. Is regular 110mm x 20mm spacing needed or do I need a fork with downhill 110mm x 20mm boost spacing? (I think downhill boost is a little different and moves the rotor closer to the fork leg than regular 110mm x 20mm)
Can I use the stock headset as well?
Yes you can use stock headset, we sell a couple on the site. I don't know about that specific fork, best would be to take measurements of everything in order to narrow down what meets that specifications. For example this fork meets the specs needed https://sur-ron.markkitaoka.com/manitou-dorado-forks/
Thanks.. Fox 40's have the same 1/8" non tapered steer tube as the Dorado and the same travel (203mm) .. all good there. The missing piece to the puzzle is the hub that is used on the Sur-Ron. Is it regular 20mm x 110mm or 20mm x 110mm DH (downhill) Boost? This would be good to know to keep Sur-Ron owners from buying the wrong fork (Fox 40's are spendy.. would be a huge bummer to buy one with the wrong hub spacing)
FYI.. if the regular vs DH boost question above is confusing (as it was to me initially) .. the link below will describe the difference in detail
Originally posted by CPG View PostI oil my chain by suspending the bike in my shop from the seat, and goosing the throttle while i slobber the chain lube on. Been doing that way for years, but just recently, I noticed a new noise, ONLY with no load, with the wheel suspended. Riding, it's as quiet as ever. I read up on the lube procedure, but only did the right side, using Mobile 28, with no difference being made. BBSHD, about 2500 miles. I know the noise issue has been beat to death, but I am unclear as to whether or not it matters if it only happens with no load on it. My next move is to run it up with the big ring gear off, to see if it still makes the same noise. I didn't know about that trick until doing some searching here. I've never messed with the left side, where I understand the plastic gear is, and I STILL don't see the logic of greasing a plastic gear.
I have the big ring gear off, and the noise persists, it seems to be coming from the bearing the spur (the smaller) gear runs in, got to youtube to see how to get at next.
A few hours later: It seems the problem is the roller bearings inside the nylon gear, sticking my finger in there didn't feel "rolly" at all, more like a bushing would feel. The teeth were fine, and as I have a very low geared Rohloff hub drive and the hot rod 1300 watt tuning plus like to do lots of wheel stands and generally ride it hard, that is encouraging. But for 20 bucks, and as long as I have apart, I'm not counting on the fresh application of Mobile 28 grease freeing the rollers up, I have a new one on the way. A bit of pain but this motor has 3 (4?) seasons of all the trail riding I have had time and energy for, without a lick of trouble. A few hours and less then 30 bucks is a small price to pay, and I now feel much better seeing and knowing how the motor is put together.
One thing, the three phase wires can't pass through the case, (so I can't take the motor clear off, I have it hanging by a rope so I don't put any stress on them where they connect to the coil) the holes are too small for the connectors on the ends to pass through. If there is a way to release those connectors, short of cutting the wires off, I couldn't figure it out. I should mention I didn't remove the motor from the bracket bracket, as I didn't want to mess with the wiring from it to my breaker and then the battery. It would have meant a fair bit of extra work as that is all covered by my zip tied frame bag.Last edited by CPG; 10-29-2019, 12:58 PM.
That's a reasonable way to do it. Pull the secondary reduction gear first, then pinion, then nylon gear. None of that stuff needs to be there to bench test.
This tutorial is to do maintenance on the BBSHD<br><br> You better don't take any chances and order a paper gasket they break very easily, Click here. (https://lunacycle.com/parts/bafang-parts/bbshd-parts/gasket-for-main-steel-gear-bbshd/) <br><br> Tools needed:<br> You will need a small blade
Also check the clutch when you remove the secondary, just to rule that out as well.
Apart from that there's not much else in the way of moving parts besides the rotor itself and a couple sealed bearings.
I think I've mentioned before that I plan on doing a touring trip. I plan to do that in the spring of 2020. I do not want to get stranded on this trip and have no problem carrying back up parts for my BBSHD.
The parts I'm thinking to carry spares of: 2 clutches, 2 nylon ring gears, 2 speed sensors, a spare parts kit, a thumb throttle, a Display. Is there anything else you would add to that list in the way of parts?
The New Metal Gear available brings about questions of its own. Would swapping to the new metal gear option eliminate the nylon gear failure point? or just make things worse if they did fail? I dont beat on my bike but facts are facts I go 385 lbs and the bike is geared to haul me up the steep hills where I live (30T Mighty Mini 11-36 rear) all while towing a cargo trailer loaded with 90+lbs. Top Speed is 23 mph max on the flats.
I currently have a 40T Mighty mini and a 11-46 10 speed Sunrace Cassette I may have installed by the local bike shop. From what I gathered I will still have the same low range with this combination but will pick up some more Top End. Not sure how I feel about that if its good or bad. I know it should increase my max speed on the flats which would increase the amount of mileage I could cover in a day. Not a speed demon by any means but I think its nice to have the ability to even if I dont use it all the time.
I have my breakdown kit for basic bike maintenance, flats and chain breakage and carry a basic multimeter (the one Luna sells) in addition to my basic bike tools.
Would you carry a spare controller too? I mean if that went my trip would be over. Is there anyway to tell which controller I would need without doing a tear down?
My plan is to visit Niagara Falls do some site seeing in Buffalo and ride the Eerie Canalway Bike Trail while collecting any National Park Cancellation Stamps along the way.
If this goes well I will plan to do the entire Empire Trail and maybe even keep going. But I dont want to get ahead of myself. The Erie Canalway Bike Trail is the trial run.
Plan B is Van touring and using my ebike to explore towns.
The cross country from DC to the West Coast was my initial plan! This is my shake down to see if I can actually do it and if its feasible with my limitations.
Is that Pinion easily swapped out? After reading those articles it seemed like the solution was to get a new motor core. Making me wonder if I would be able to fix that on the road or it would be a trip ender anyway.
How much can actually practically be done on the side of a road? The ones that seem doable are the parts I already listed. I it practical to think Id be able to change that pinion gear on the side of the road or the secondary reduction gear. For practicality purposes what should I have as spare parts if this happens so I just have a complication not a trip ender?
I know this is a lot of what ifs? But Murphy man he's usually right! Should I have a 2nd BBSHD unit on stand by to ship out? What would you do? I mean on this trip in particular it's not that big of a deal. I call and get a ride home at worse. But, if this goes well I will be on the road for the long haul and looking at those logistics. Parts arent always readily available. I'd hate to be in PoDunk USA stranded because of a part that's easily replaceable and I just dont have it. I have no issue with being down for a week or so waiting on a parcel in the post to do a repair. But, I think waiting months for that part is impractical.
Ultimately I probably should have another BBSHD unit ready to go but thinking that may be overkill.Last edited by pure_mahem; 10-30-2019, 12:57 PM.
Warning - I'm just typing out loud here.
How much can actually practically be done on the side of a road? Great question.
For long-haul, multi-day rides on flattish, converted rail or canal paths, is a mid drive the right answer versus a gear reduction hub motor? Is a hub motor (like the Bafang 500 watt geared motor) easier to repair and carry spares for?
Hi, after about 7500 miles of commuting I finally took off the cover to the secondary gear reduction because I started feeling a vibration in addition to the squealing it had been making under load. I realize that I have grossly neglected the drive and have never added/replaced the grease. So as I crack open the case it looks like salt bay had seasoned my drive with stripper glitter. It turns out the main steel gear has mostly turned to powdered metal and whatever grease was in the drive originally had long since cooked off.
My plan is to replace and liberally lube:
The steel gear with the assembly that Luna offers
New pinion from Luna
Nylon gear from Luna
Bearings for the pinion. The main one that is pressed into the case and the one that is in the nylon gear cover plate/bearing block.
My question is does Luna or another bafang dealer stock them and if not what are the specs.
Also, side note: I put it back together and added a bit of Mobil 28 to the pinion so I could commute to work today and its purring away quietly but still with the vibration from the steel gear with light weight teeth.
Thanks!
4 Photos
- Likes 1
The pressed in bearings are not typically replaceable. But they're sealed bearings and should be fine. In theory you can remove the seal with a pick and add more grease if you wanted to but I would not do it unless necessary. Rotor bearing on the rotor where it meets the housing uses a NSK 628VV bearing if you need a replacement.
Here's how to repack a sealed bearing https://www.youtube.com/watch?v=Np5dcns64Fs
Not sure the controller has been damaged. I see some indications it may be okay; I have to get that wire fixed first. Any chance of acquring a set of the plugs that got eaten?
Is it throwing an error? If so then it's probably not going to work. If you can separate any severed wires from touching eachother and run it like that then maybe okay. Here's a source for HIGO plugs https://www.e-bike-technologies.de/index.php/en/
