Hi Mark!
The sound could be a few different things, most likely is probably the chain slipping a bit, and you might want to check whether it happens in particular gears more than other gears and check how good your chainline looks. You could also try out one of the aftermarket chainrings that has narrow/wide teeth if you are using stock currently. Narrow/wide has a much better fit for the chain.
Alternately it could be that the motor is banging up against the frame when you hit the throttle. So you might want to check how tight you have the lockrings and check your clearance. If it's neither of these things it might be internal, and you can pop it open to have a look, or email support if you need further advice on it. See this section on the wiki for how to pull it apart if needed, but it's likely the chain. https://www.reddit.com/r/ebikes/wiki...roubleshooting
For the shark notification that's because we ran out after we shipped your order and it's temporarily backlogged.
For the display what you are seeing is voltage sag. We cover this briefly on the documentation for the battery.
For the display you can't really go off of the gauge for anything other than a vague idea of the state of charge, that's why the more advanced displays show voltage. You can combine the information you have on voltage with the voltage tables we have on the battery documentation to get a better idea of how much is left in the battery. Additionally most displays cannot set the gauge for a 52v nominal pack so it's going to be even more off than it would be with a 48v nominal battery.
Why does my voltage drop after a full charge? |
All lithium batteries have a little voltage sag from where they are when fully charged. The amount of sag is proportional to the number of cycles and how much its been through (heat, repeated deep discharge, pulling more current than the stated continuous discharge rate, age). Other times you may see sag is when pulling a lot of power from the pack, especially when the charge is getting low on the pack. |
