    With a BBSHD and Ludicrous controller, I have twice flipped my rigid frame fat bike over backwards while climbing up a steep rocky trail. Was using the throttle both times as the trail had too many protruding rocks to allow pedaling.
    I am building a second bike with full suspension to hopefully at least help reduce flipping over backwards in the future.
    My question is whether or not an incline switch is available that would turn off the motor at a high angle? Would want the switch to turn off the motor in one plane only. Something like when the bottom of the front wheel is higher than the top of the rear wheel. Seems like the existing brake shut off switch wiring could be connected to an incline sensor if one exists. Thanks for any information or pointers.
    • 73Eldo
      73Eldo commented
      Interesting idea. You have the brake and gear cutout circuits you could use to actually do the cut and there is power available in those connectors so maybe you could do something Arduino based? Thinking you would want some sort of reset button if it did cut? Otherwise seems like it could get ugly, you manage to save it once but start to lift it again and you could end up in an oscillation trying to keep your balance on the side of a mountain.
    • CC Rider
      CC Rider commented
      72 years old + rocky single track hills + Ludicrous controller? I'm 63 with a 27.5+ hardtail eMTB using a BBHSD in Hot Rod Mode. Never came close to going over backwards in similar scenarios. Perhaps downgrading your controller would be more cost efficient and safer?
    If the motor cut off even momentarily, that would give my 72 year old reactions enough time to remove my thumb from the throttle. The backwards flip has occurred when the front tire bounces about a foot off the slope and then slams down on another protruding rock so that the first bounce is amplified. Even at low speed, the torque of the BBSHD is enough to push that second bounce over the top. I am momentarily just trying to hang on and so far have not had the reaction to remove my thumb from the throttle. A half second cutout of the motor could solve the problem. I will google Arduino-based. Thanks for the suggestion.
    • 73Eldo
      73Eldo commented
      The Arduino is basically a very popular (and inexpensive) universal mini computer that can be programmed for millions of applications. The reason I would consider using it for this application is I think you would not simply want the motor to cut literally every time you hit a certain angle.
      If you were using a simple mechanical switch it would make contact just from the inertia of acceleration and deceleration which would be no good for this application. Think of a wire just hanging in a circle and if it swings and hits the circle you make contact. Maybe this could work if you could say only cut if the contact is made longer than so many milliseconds which is something you could program the Arduino to do. Maybe even a combination of a sensitive and less sensitive one and you program it that both have to have contact for a period of time.
      If you use a more fancy sensor you would need some sort of computer to inturpit its signals. I think you can get tiny little chips that can sense angles and acceleration separately. Phones have them now days and that is how they know which way you are holding them and how you can shake them to do things like turn on the light or camera. You have to program the Arduino to monitor those signals then tell it what sort of signal sends the signal to the drive to stop.
      None of these parts are expensive, guessing well under $50 and the programming isn't for someone that can barely use a smart phone but isn't something that takes years to master either especially for something fairly simple we are talking about here. The fun part of this type of thing is it does start simple basically you say if sensor reads this for this long do this for this long. Where it gets fun is you add a second sensor and say only do this when this and this happen. Then maybe you add some sensor in the seat so if you are not seated it changes the timing then you add some other sensor and add more conditions. It can be a lot of fun to play with and keep expanding and refining what it can do.
      Not sure about the rest of the world but in the USA Adafriut is a good resource for the hardware and also has a lot of how to info.
    Bafang 8Fun 750 motor Controller blew two MOSFETs. I have replaced all the MOSFETs with new higher rated ones but the controller is still not working. The display screen and lights all work and the PAS has a little flashing led when the pedals are rotated. There is a red led inside the controller that is flashing a sequence of 6 then pausing like an error code. Any ideas.
      Best idea would be to replace the controller outright. I would not be surprised if when the fet blew it did some sort of cascade failure. Nobody replaces individual parts on those controllers, especially since they are potted (this is assuming you are referring to a bbs02 of course)
    can you put a sabvoton controler on a sur ron
    • marcdryb
      marcdryb commented
      ok then ill try it and can we put a 72v on the stock controler on the sur ron even if its a 60v rateded
      Stock controller would not work with 72v
    • marcdryb
      marcdryb commented
      ok thxs that helps a bite i could have burn it down
    I built my own E bike battery:
    48v, 13s, 5p for 1000w fat tire rear hub motor. Installed in OCC chopper bike. On the throttle handle there is a power button and three lights that indicate The level of charge on your battery. Starting from the bottom there Is a red light then an orange light then a greenlight. As you can imagine the green means the battery is fully charged and as The power decreases there’s only the orange light and as it decreases further it goes down to red. After initially building the battery I quickly strapped it onto my bike I had fun riding it around for a while and it seemed as if the charge lasted forever. As well the indicator lights would go from green to orange to red light overtime and incrementally. Due to some repairs needed on the bike I took the battery off and the battery set unused in my garage for about two months or so. After repairing what I needed to on the bike I recharge the battery and plugged it back into my bike. However while riding every time I turn the throttle the indicator lights would go from green down to red and back up to Green and Down to red depending on whether I was twisting the throttle or not. If I was not twisting the throttle The light was on green when I would twist the throttle it would drop down to either orange or red. This had not happened before. As well it seemed that the battery drained very fast. Upon bringing my bike back to my house and plugging it to a charger, it seemed like it charged in no time which is fishy. It is a four amp charger with Anderson connectors so it’s a decent charger but the battery is now fully charging (well supposedly) (indicator light on charger turns green) in 1-2hours. Seemed like it took longer previously. Battery still draining pretty quickly on a full charge.
    Did I ruin my battery by letting it sit in garage for a month or two?
    Is there a way to revive my battery to its former glory?
    Thanks!
      This thread is meant for asking luna questions about luna products but i'm sure if you repost this on a separate thread folks would be happy to chime in!
    Hello guys
    i have a BBS02B 750W motor with upgraded luna controller
    i rode the bicycle the other day during a heavy rainfall.
    Since then, while on PAS the motor randomly cuts off and resumes operation randomly and continuously, i couldnt observe any pattern, it seems completely random.
    The throttle operation is working perfectly , i get continuous 1200+ Watts without any issues
    Would you think its likely that humidity entered in the controller
    I would greatly appreciate your feedback
    • 73Eldo
      73Eldo commented
      The rain before the problem started seems like there is a decent chance something got wet. There are videos online showing how to get these things apart. Usually they are doing it to change the nylon gear but it still shows how to get it apart. There are some videos that also show ways to better seal them up.
    Which version of advanced charger do I need for my x-1 bike. 48v or 52v?
      You would need 48v
    I bought a BBSHD From not Luna (:facepalm) and the display always showed the voltage of the battery ~5V less than actual. I tried programming the firmware and metering out the voltage, and all looked good. And then the controller stopped responding.
    Is Luna Cycle open this Wednesday (December 23rd) for me to come pick up a TypeB BBSHD Controller?
      Currently we are only open for bike pickups on Wednesdays, not for small items
    Sounds good, remember to forget the shipping option to pick it up. I’ll have it shipped.
      Are pas sensors available anywhere for the BBS02? I think mine may be bad. I'd seen people on other forums say they've bought them, but I haven't been able to get a hold of any of them yet to ask them about it.
      Thanks
      • 73Eldo
        73Eldo commented
        Pretty sure I remember seeing them being sold somewhere and that they were listed as fitting all 3 models of BBS's. Just don't remember where. I think I noticed it when looking for something else I didn't find is why I didn't note where.
      Thanks
      Here's a U.S. source for the sensor and the related magnet disc.
        I have the cyclone mini motor using it on a drift trike, are there any motor sprockets that are larger than 14 tooth that are compatible? I'm looking for something around 20 tooth.
          I don't think so..have you tried cyclone's website?
        I recently bought the Luna Eclipse 42T chainring for my BBSHD, to fix the chainline issue I was having.
        Can Luna recommend a chain guard that fits over the 42T? I got a cool, new Hebie chain guard, but it doesn't fit over the chainring bolts.
        Thanks in advance, -Peter
          I know of no chain guards that fit over that. I have seen a DIY guard someone cut out of plastic, that's about it
        • Bullfrog
          Bullfrog commented
          blueclaws...two things I do:
          A. I tie my shoe laces in double, triple, quad or just keep tying multiple knots in my laces until they are too short to reach the chain ring/chain intersection. My buddy just uses duct tape and tapes over his laces to keep them out of the way.
          B. You might also want to do something to keep your pants leg from getting caught in the chain rin/chain...I use a big rubber band around the bottom of my pants leg. Had my pants get caught one time and rolling the bike backwards doesn't help because the freewheel spins and the motor won't turn backwards and I couldn't go forward because my leg couldn't pass the pedal/crank arm. My buddy had a knife so I ended up cutting my pants leg off which of course ruined my relatively new pair of Levis.
        Bummer. Thanks for the quick reply.
        I wonder if I am overly concerned about foot/shoelace safety. When I am in throttle mode with my BBSHD (i.e. no pedaling), I see the chainring under me spinning at a very fast speed, very close to my shoes/laces which are stationary on the pedals. I get nervous about a high speed chain / high torque motor / gear teeth accident happening when I move my right foot into the wrong position. In contrast with pedal assist mode or a regular bicycle, feet and chainring/chain are moving at same speed and less chance of an accident happening. Or if an accident happens, you're quickly alerted to it and stop pedaling before it gets worse.
        Thanks, -Peter
        • 73Eldo
          73Eldo commented
          Its a good concern to have because with the motor just because you stop pedaling doesn't mean its going to stop sucking you in. I got my pants leg stuck on my bike with the Lekkie and I was really stuck. I was riding SPD cleats and boots so I really didn't have options other than to try and reverse which wasn't easy in frozen snow. I was riding for several hours earlier the same day with the same boots and pants on my bike with the eclipse and never had the issue I think because the offset is so great you really have to have something loose to get up there.
          I did find a 3d printed guard for the Lekkie and it seems to be holding up OK. Not sure if its working or not because I now have pants that fit my boots really well. I'm thinking if you had something like shoe laces that were so loose they could catch on the eclipse I'm not sure a guard would help.
          Have you explored more cycling specific shoes? Many of them either now use the BOA system or have a velcro strap flap sort of thing that goes over the laces.
          That was my conclusion as well. I'm sure I have friends that could slap together a chainguard even if it's just something you ziptie to the frame, but if your clothes are so loose that it is a concern, you should be wearing different clothes.
        Thank you very much. Much appreciated.
