Have a surron here that runs fine except won’t go into sport mode, took switch apart and all looks clean dry and good contact, the green wire is cut and not touching and when plugged in the light is a continual slow blink. Do you have any advise of where to start?
Well I suppose you could just take the parts off of one of your other bikes and swap them around. Wouldn't cost you anything and looking at your order history it appears that you have multiple bikes to do that with. If you do so, and it is for example the controller, the issue will follow that controller when you swap it to another bike.
Hello! I built this bike a while back:
Hi! I was inspired by Rider's build: https://electricbike.com/forum/forum...v-custom-build (https://electricbike.com/forum/forum/builds/custom-builds/21424-soma-b
with a sturmey archer 3 speed and 50/20 gates belt drive cogs. I've decided that I want a larger spread of gears (higher top speed mainly but also some lower gears would be nice for starting on hills, etc). I am considering upgrading to a rohloff hub. I used Sheldon Brown's gear calculator and to get the spread that I want it looks like I would be using 70/20 or 70/19 sprockets.
I remember back from when I was doing my research that its better for the motor to have the smallest front chainring / front sprocket possible so that the motor spins as fast as possible for a given land speed. The 50 is the smallest that can go on there and I think its about the same size as a 46 tooth chainring. Do you think that putting a 70 instead of a 50 in the front will be a problem? It looks like I will be getting a lot of lower gears too so I can even start at a 2 gain ratio instead of the current 4. I am using a BBS02 at 25 amps. Upgrading to a BBSHD is within the realm of possibility although this upgrade will be expensive enough as is so I'd prefer not to.
For reference, here are the gain ratios:
Current SA 50/20 (top speed about 23mph, sometimes have to start out of the saddle up hills):
GR 4.0 / 5.3 / 7.1
Rohloff 70/20
GR 2.0 2.2 2.5 2.9 3.3 3.7 4.2 4.8 5.5 6.2 7.1 8.0 9.1 10.4
Rohloff 70/19
GR 2.1 2.3 2.7 3.0 3.4 3.9 4.5 5.1 5.8 6.5 7.4 8.4 9.6 10.9
I'm hoping to get the top speed up to 28-30mph while getting an easier gear for starting up hills.
Thanks in advance for your time!
Gerry
BBSHD Issue: Throttle and PAS are unresponsive. Backing up the bike a few feet (back-spinning the motor) brings it back to life: both throttle and PAS. As long as you keep the motor spinning, throttle and PAS remain responsive. If you let the motor come to a stop, you lose Throttle/PAS, and have to back up a few feet to get going again. The only thing hooked up to the controller is an Eggrider V2. This is the oldest of my BBSHDs. I wrote up the Giant Stance build on this forum.
Been gone for several weeks and had to put this off. Working on this today, I was able to test the Hall sensors. They are all switching on and off, but the voltage to the Halls is 2.7V. Does that sound right? The Grin doc has the voltage between 4 and 5 Volts. I've also sent an email to Luna (Seb), but that was Friday afternoon, and haven't heard back. If you know the Hall voltage, that would be great. Otherwise I'll work the email. Another interesting find: the phase wires had knockoff Anderson connectors, and the plastic housings on 2 of the phases were partially melted and stuck together. Contacts didn't have any arc-burns.
After testing the Halls and replacing the melted knockoff Powerpole connecters with genuine, I put everything back together and.... The problem vanished! Must have been the melted Powerpoles. The green was in good shape. Both the blue and yellow were badly distorted. To be fair, the knockoff Powerpoles lasted many years and thousands of miles.
I need help with my bafang 1000 watt mid Drive motor I was trying to update firmware and software on the motor and I not sure if it completed but when I use the diagnostic tool I accidentally put my amperage 231 not 30 and it has a quotation mark on the display but now that I was messing with the software that now it doesn't even turn on so I got a whole new display and it still doesn't turn on in anybody help me what do I need to do or where do I need to do to get the right software or firmware Ford truck to work please help help help
Originally posted by Realdeal562 View PostCan some. One help
Hi Guys !
I've been running a BBS02 since 2018 with more than 7000km in Montreal, Canada all year round, so through winter (i.e. snow and salt !) and hot summer. The kit has been pretty reliable but my chain and cassette are wearing out so fast and I'm having a lot of "slipping" of the chain on the smallest cogs at the back that are 14, 16 or 18 teeth ! The peak power is 1350W so not as much as an HD (Peak@1600W) or a Bafang M600 (Peak@2000W).
I searched a few times for specific heavy duty chains and cassettes but could not find anaything interesting.
So I wonder if something exists? And I wonder if lunacycle are using specific chains and cassettes on their high output mid drive power units?
Thanks for any elements of answer !
Ride safe !
1 Photo
How many miles/km's are you getting out of a chain and cassette? Salt is really hard on em, most people say if you can get one winter out of you are doing good. I know many people that put new on in the spring and just hope they make it to next spring and those are often not even on E bikes.
- Likes 1
Originally posted by 73Eldo View PostHow many miles/km's are you getting out of a chain and cassette? Salt is really hard on em, most people say if you can get one winter out of you are doing good. I know many people that put new on in the spring and just hope they make it to next spring and those are often not even on E bikes.
