    The drop is significant, my daily is about 12 miles mostly flat, rarely I drop more than 2 bars, now I at the end of 12 miles I'm left with 1 or 2 yellow bars, dont know how the readout is calibrated but looks like 200% plus battery usage.
      the drop in power is significant I would say 50%, so another thought, when I was changing the motor I pulled out a bit the battery pack for convenience of reconnecting, is it possible that I might have unhooked one part of the pack?
        1000 cycles is a fair bit, even if only to 50%
        Usually the first thing I notice in older batteries is they start to sag worse and worse, particularly at lower SOC's (voltages)... I see it start on batteries with as little as a couple of hundred cycles and it only gets worse with time... the most cycles I have on any battery (I've got about half a dozen) is around 300 but many of the cycles were discharged down a lot less than 50%... their total capacity reduction is only about 10-15% less than new but the sag makes the useful capacity a lot less, at least for any "spirited" riding... admittedly they'll get me home with a lot less spirit...
          Looking into a new E bike for hunting looking for suggestions price range is 1500-2500 also interested in a cart for hauling in and out of the woods
            Best for that price range is putting a BBSHD kit on a fatbike. ~700 for kit, ~700 for bike, and the remainder for battery and any needed extras.
          My personal build is back up and running again! Made 4-5 commutes now without any issues.
          I'm building a bike with BBS02 for a friend. The controller has a lead for headlights, and the kit got delivered with some headlights as well.
          I think though that I've read somewhere before that using headlights attached to the controller can break the controller. Is this right? Or has it been solved in current revisions?
          • Retrorockit
            Retrorockit commented
            I can agree with all the reasons not to use a dynamo. But If I already had one the cost/ benefits would be completely different.
            I think the 1160 W/h battery is great. Mine can go long, it can go fast, and it can buck 20mph headwinds. It can almost do all 3 at once.
            I have a 1500W BBSHD and I don't need to dial back anything. Why do you?
            Forget all of the theoretcial crap and just ride the hell out of it. Then tell us what happens.
            I have a huge collection of Niterider rechargeable off road headlights all the way up to 1200 lumen dual LED version. The one I actually use daily? The oldest weakest 350 lumen version. Stupid fast day strobe, and long runtime with a new 3500mA/h 18650 battery(up form 2200mA/h).
            I think what you have will work just fine. IMO with that battery you don't need to tweak the motor settings to death.
          • Pizzabroodje
            Pizzabroodje commented
            @stss
            I still don't get the relay thing, might look into it more later.
            I know a dynamo isn't efficient but I'm not worried about that because of the small amount of power it uses. For me the trade-off towards an easy and safe solution for lighting is worth it.
            @retrorockkit
            If it was my own bike I wouldn't set it all down. I have a BBSHD running at 30A too (just set it too that a few days ago when I found out it was set to 27A).
            The bike is for a 60+ y/o guy however, and speed limit for ebikes without requiring registration and a numberplate is 25kmh, so it's already illegal like this. It's also a pretty clumsy and heavy bike: Batavus Deliverybike. Going much faster on this is just plain dangerous.
            He doesn't need or even want to go faster than 35kmh. Running it down just makes for a smoother power up, putting less stress on the motor and drivetrain, making it more reliable and more likely to last 10+ years; which is what he wants.
          • Retrorockit
            I'm 69 years old. My bike weighs 72#.. Sorry to hear about the 25kph limit there. 28mph is the limit here. I ride mostly legal speeds. The silence of the BBSHD helps a lot with stealth. But on a 45mph highway I will open it up to get out of that situation. But I can see building an outlaw bike for someone else could be an issue.
          I got an issue with my BBSHD after changing some of the controller settings:
          ​​​​​​When pedaling and throttling at the same time, and then stopping to pedal, it'll drop to the power of the PAS instead of the power of the throttle for a sec, before going back to the power of the throttle. So in PAS 0 it'll drop to 0W for a sec when stopping to pedal before going back up to 1500W all while using full throttle.
          Throttle also doesn't seem to engage before putting more power than the set PAS level while pedaling. So if in PAS 2/9, and using 500W with throttle, and I start to pedal, it'll drop to 250W. If I then increase throttle to a certain amount it'll engage again.
          The only setting that I changed that I think could've caused this is the throttle end voltage (I changed that from 35 to 42).
          I didn't change too many other settings. If I recall correctly, I changed...:
          -...the Current Limit to 30A from 27A.
          -...the PAS1 Current Limit from 20% to 10%
          -...PAS Start Current to a lower value (I think 5 or 10 %)
          -...Slow Start Mode from 3 to 4
          -...throttle End Voltage from 35 to 42
          -...throttle start current from 10 or 20 to 5% (I think)
          Might also not be caused by programming but something else, but it came right after programming it, so I do assume it's this.
          • Pizzabroodje
            They confirmed to me that it's the firmware. They said this:
            "Yes, this has been how the BBSHD motors works since 2019. If you’re pedaling you need a greater throttle input to override the PAS. If you don’t pedal throttle requires much less input to affect the motor. Originally the BBSHD motors didn’t function like this – but Bafang made changes to the firmware back in 2019 and this is how they behave now."
            I did manage to at least remedy the issue of it going back to the PAS power for a sec after stopping to pedal by setting the throttle settings back to Em3ev's standard settings.
            There's also a jerkiness when pedaling and keeping the throttle right at the point where throttle takes over from PAS. (Also after changing the settings the first time)
            I think I'll just change all settings back to default to see if that'll solve that issue at least. If it does, I'll try just changing the start currents and slow start mode (or might change everything back to default except this first).
            I'll attach screenshots of the settings as I had it to the main post.
            Would it be worth flashing another firmware? Is the firmware that you use for your BBSHD's available anywhere?
            The custom firmware you mentioned is the one by danielnilsson I assume? That indeed looks like a great project!
          • Retrorockit
            That is interesting. It explains the jerky throttle response, but with the zip tie casstte mod it cruises around easily just standing on the cranks not pedaling. Now that I know this I can play around with it some.
            There are firmware version out "in the wild"
            Potential issues with changing firmware is that it's impossible to read the code that's in there to return to it if the new firmware gives grief which could potentially happen since not all hardware is the same (this doesn't seem to have bit folks though) and there's a small chance of bricking the controller
            There is a way to change the settings so that the throttle works great while pedaling but it will disable PAS entirely
            There are also fairly simple hardware modifications that address the problem (feature?)
          As a follow up on this post about the charge limiter circuit:
          ​​​​​​https://electricbike.com/forum/forum...484#post157484
          I guess I should've phrased the question there differently:
          If the chip in between the charger and battery fails / shorts out, would the charger and battery fail consequently? Or would the safety features in those prevent that from happening?
          And certain types of AliExpress sellers do lie in their ads indeed; however, there are many honest sellers / brands that don't. Especially with stuff like this they won't be eager to lie about it.
          Also, I'm not adding it for extra safety, but to limit charging to 80%.
          For two of the chargers I need some DC connectors. I found some that are compatible with 24V / 10A; would this also work with 48V / 3A? I'd guess so as it's less wattage at a higher voltage, so less heat is generated?
          • Pizzabroodje
            Interesting idea but not for me. I like the idea of having a little box to plug in between the battery and charger, and just take it out whenever a full charge is needed. It would also be used for most charges, so not only for storage.
            The boards are cheap too. They were just €5 a piece including shipment. A nice plastic box to put it in is about €5 too, the 24v 10a connector mentioned is €6, some cable glands €0,5 a piece. I still have some XLR connectors from Luna for the ends of the chargers and for the end of my own battery (making three of these for myself and two other bikes with the same DC connector, their chargers have an XLR connector and XLR to DC adapter though).
            Add it all together it's about €20 a piece. IMO it's a nice solution for that price. Would prefer a charger with limit setting, but those are way more expensive (3 Luna chargers would cost me €435 with shipment, taxes and duties). And my Luna charger doesn't charge to 80% anymore, only 90 or 100, so I don't know if that'd even be a more durable solution.
            I can also add a fuse for extra protection against shorts (still have some fuse holders laying around too). Would this be best put on the end of the charger or on the end of the battery? (Or both?) I'm guessing on the end of the battery?
            And any comments on what DC connectors to get?
          • Pizzabroodje
            I ordered those. Everything arrived today, and I put one together to test. Everything works just fine. I checked with a multimeter too, and the voltage displayed on the board was only 0.2V off.
            0.2V off may be the DVM you are comparing it to, most inexpensive meters' accuracy is worse than that in the range for ~50V, some quite a bit more...point being it really depends on what you are comparing to as "the gospel"
          For a Luna Eclipse folder I'd like to tune the suspension for my weight. I am focusing on the rear shock currently. The fitted stock spring shows 750lbs and I should be more around 470lbs for my weight (180 lbs). The stock coil shock has a 45mm stroke length. Would a 45mm/1.77" x 400-488lbs progressive spring like the one here from Cane Creek be a good fit? https://canecreek.com/product/coil-s...r-progressive/
          Alternatively, would it just be better to source a better shock? It is an odd size (150mm i2i x 45mm stroke) so it seems like options are limited. I would think just getting the correct spring rate for my weight would help a lot as I'm probably not moving that 750lbs spring much, but I'm new to this.
          Thanks for any help!
          • Retrorockit
            Spring rate is not as simple as it looks if there is a ratio of travel between the spring and the axle. Say the ratios 2:1. Lets make the soring 800# / Inch.
            The wheel moves 1 inch. The leverage reduces the rate to 400#, but wait the spring also only moved1/2 inch which is also 400# so now it really only takes 200# to move the wheel 1" with an 800# spring. So you need to know the ratio, and then then divide by the square of that times the spring rate is the rate at the wheel. Also on that bike those chubby tires are the first line of defense anyway. I would ride it and see how it actually works before getting all worked up about the numbers. If the ratio is 1.5 to 1 then that 750# spring will be about 333# at the wheel. On a suspension fork it's pretty simple. But on a leverage type suspension it's not.
          My surron light bee 2023 wont go, all the sensors are remvoed such as the break, kickstand, and tipover. It will move a tiny but but then cuts out. Does anyone know what to do?
          Hello I was wondering if LUNA CYCLE could send a sur ron x to quetta hazara town could u guys please tell me
          Hi, My blue 72V 300W Ebike Advanced charger from Luna stopped working. My son said he heard a pop and saw some smoke, when he plugged it in indoors on a cold day. Is there a common fail point in this charger that we could fix? Perhaps a MOSFET or capacitor? The fuse seems fine. The Luna 72V battery pack is still in great shape after 4 years or so.
            I'm back with yet another problem...
            My BBSHD came loose and started making a cracking noise.
            I fixed the BBSHD again but the cracking didn't go.
            It happens both with motor on or off, and both when pedaling or throttling.
            The steps I took to try to fix this:
            - I took the BBSHD out and inspected the frame for cracks. I put some aluminium foil around the BBSHD shaft (so between the motor and frame) to make the play less.
            ​​​​​​- I checked the chain for visible damage, and put on a different derailleur (as that appeared to have it's own issues).
            -I checked if all bolts were tight
            What else can cause this? I read that the clutch can cause cracking, but would that be similar to this? I guess that the Nylon and pinion gear can't be the cause as it happens with the motor off too?
            A video of the noise while using the motor's power:
            video, sharing, camera phone, video phone, free, upload
            A video of the noise when pedaling with the motor off:
            Click image for larger version  Name:	IMG_20230129_162506.jpg Views:	9 Size:	328.7 KB ID:	159539 Click image for larger version
            • Pizzabroodje
              I opened it up. (Luckily didn't break the seal doing so)
              The clutch indeed looks broken, though now I'm not sure if it's supposed to look like this (added a picture to the main post). Everything else seems fine as far as I can tell.
              The BBSHD came loose as in the bracket nut came loose causing the BBSHD to rotate inside the BB. I must admit that I was lazy and held the motor against the frame with my left foot and slowly throttling (the noise already was there though at that point). Only after a bit (I think 5 minutes at most) I decided to just walk the rest of the way.
              I'm familiar with the seat post creaks and stuff like that, but this isn't a regular creak. It happens only when there's force being applied, either by only the motor or with my feet. It occuring with only the motor putting in force rules out the pedals and cranks.
              If it's not the clutch or something else in the motor the only other thing I didn't check that it could be is the Nexus 3 IGH. That also seems fine though and I don't see how the motor coming loose could cause that to break.
              Is it possible to run the motor without a clutch? Should be possible but just no way to pedal, right?
              This way I can rule out everything else and use the bike until the new clutch arrives.
            • Pizzabroodje
              I'm sorry I forgot to add it. Just did.
            • Pizzabroodje
              I thought the ring around the clutch was supposed to be one whole piece, but I guess that part is as it's supposed to be?
              I'll add another pic from the top, doesn't look too rounded off to me, and it does grab onto the teeth.
              The grease did look quite dirty so I was already thinking of replacing most of it.
              Anyways, the clutch doesn't seem to be the culprit.
              The noise still exists without the clutch (and didn't put the cranks on either).
            The noise still exists without the clutch (and didn't put the cranks on either).​
            This is what the clutch is suppose to look like - the pawl on the lower right is just cocked off to the side - would be rotated to the same as the other two before inserting
            And this is the outer portion:
              There are 2 places they suggest lighter grease. One is the pawls. heavy grease can get in the way or slow don the movement. They don't need heavy lube because when engaged nothing is moving there. The other is the roller clutch inside the plastic gear. Don't pack them full or the parts can't move, and light grease just so they don't get stuck. The roller clutch actually needs friction to work.
                Probably more about the liability than the cost but we are working on a number of game-changing things that do indeed require most of our budget. Main thing is the liability though. You would not believe some of the ways people manage to mess up a kit build, and for whatever reason the ones that mess up the worst always seem to blame anyone but themselves.
              • Retrorockit
                My backgorund is hot rodding and there is a huge aftermarket there selling brakes,tires, suspension, power and driveline parts.The bigges legal issue there seems to be emission control. Not sure how they do that. But that background helps me understand tires, brakes, and suspension in ways that most casual bicyclists never have to consider. Hot rodders seem to know how their cars work. Bicyclists seem to be mostly clueless.
              • Retrorockit
                The jail birds just steal bikes because the cops consider it a misdemeanor, and don't investigate. That's how they beat recidivism.
              I think the next step for me is to mount the kit on another bike, so I know if it's the motor or something else like a crack in the frame.
              Am I right with my assumption that it can't be the nylon gear or rotor as it also happens with the motor off and just pedaling?​​​
              • pbreezy
                pbreezy commented
                The stationary motor flex video is very interesting. I see the Bafang spindle moving in relation to the bottom bracket and the click when it engages sounds very much like the noise while riding. I would check the inner lock ring (with the four notches) tight again, as the outer lock ring could just be tight against the inner one, leaving some play in the bottom bracket interface…
              • pbreezy
                pbreezy commented
                Also make sure the retaining plate is facing the right way; the protrusions should be digging into the frame not facing outwards… just thinking out loud here.
              • Pizzabroodje
                I made sure to get the inner lock ring as tight as I could when fixing it again after it came loose. The retaining plate is also facing with the notches inwards as it should.
