I think my factory stock cyclone 3000w controller is bad, new on arrival. Here's what it does. The battery is a 60v triangle and fully charged according to the charger (although it seems that shuts down at 90% 65 volts?) So 65 volts from the battery. everything is just the basic stock kit, nothing added. Turn the key on and it says 65 volts, give it any throttle it jerks a instant and the display counts down the voltage to zero and goes dark. You have to unplug the battery to get 65 volts back. If you lift the rear tire and very carefully give it the slightest throttle you can get the tire to spin up pretty fast, but anything over 1/16 throttle or any load on the tire it will trip off. I tried a battery BMS reset by charging through the discharge line for a few secs but no change. Then I tried running the 5 amp charger directly to the controller so no battery at all and it does the same thing with the exception it will now self reset every second. So the controller which should be good for 40 amps continuous is tripping off somewhere below 5 amps. Am I missing anything?
Is there an instruction on how to replace the stock kit with these: https://lunacycle.com/replacement-cy...-with-adapter/
I have a 48v 11.6 Luna carbon shark pack NCR-PF. It wouldn't take a charge so I tested the battery and it showed 30v. I then tried to jump it through the discharge port for a few seconds but it did not work. I opened the case and found two rows of cells reading 0.0v. The rest of them read 3.3v. This is with the BMS disconnected. I was very disappointed of course. It seems unusual that so many cells wouldn't even read a Milli volt. Is there any thing else I should be testing or looking for? No visible damage to cells.
I'm am not sure that I have tested correctly. I'm hoping I am not. With probes on either side of the same cell I'm getting 0v. They are connected in series and the other series test at 3.3v. The two rows in the middle of the pack I'm getting 0v when I test the same battery on either side. The entire group is the same way.
Email support@lunacycle.com with your order# and a short summary, Seb can provide a more thorough diagnosis.
Given your location there are also several folks you can take it to in the area to have a professional look at it. Zak can do stuff like that in his spare time, he's in Pasadena, "madman ebikes". Or BikeCraze and Board Shop a little closer.
I purchased and installed a Bafang BBS02 750w Mid Drive eBike KIT with a DPC-10 horizontal color display. It all went smoothly and was working well. Late last fall it just stopped working- nothing. The battery indicates full on its self-contained meter, but when I put it on the bike the display and bike do nothing. I recently spoke with a local e-bike guy who said that there was problem with that display, and I see that it is no longer offered. Is there any chance that the display is the whole problem? I'm enjoying the spring riding weather my normal ride, but want to start commuting again. I'm not sure where to start to diagnose it. If it could be as simple as the display, that would be great....any hints would be appreciated. Thanks
There are instructions to bypassing the display here, give that a shot to confirm if it's display or not
I've got your 48V advanced charger. Just curious if this is normal behavior... I charge my battery to 80% and it cuts off at 51.3V. If I then unplug the charger and plug it back into the battery a little while later or the next morning (battery not used in the interim), it'll consistently read 51.9 or 52.0V. The charger will start charging the battery for a few minutes even though it's already at/above the 80% threshold. If I walk away and come back 10 minutes later, the charger is off and reading 51.3V again. Normal?
Originally posted by sonnbc View PostIs there an instruction on how to replace the stock kit with these: https://lunacycle.com/replacement-cy...-with-adapter/
Support does not have specific instructions on doing so sorry..I do know the notch is a keyway and you do something with it to remove. Please email support@lunacycle.com with some pics requesting Seb to have a look, he might have better info.
I thought all the new shark batteries had gone to the five prong connector. My first build had the five prong and the metal base plate. I purchased thisabout 3 months ago. The battery I just received is back to the old 4 prong. I ned the battery to have the five prong so it is interchangeable with both builds. How can this be corrected?
Sorry it cannot be..due to the volume of batteries needed we work with many assemblers as no single company can fill our need. Due to this there can be minor variation and we cannot guarantee it will be 4 or 5 prong from order to order, though we can check stock if we are contacted first.
If looking for consistency I would recommend the Wolf pack as it is built by us in Los Angeles where we can more closely control production.
Do you have the 5 prong shark 48 volt 13.5ah in stock? If so can I ship this back for an exchange?
We don't have anymore 5 prongs in stock. Only the 4 prong versions are available unfortunately.
