Diamondback sync'r build w/ BBSHD
    Looking to build this Diamondback sync' r bike 19" lg frame with a BBSHD 1000 w . 52 volt shark pack . Can u tell me which size BBSHD unit to buy ( bottom bracket pic enclosed) and would this bike make a good build. Like riding single track and fire roads but want to be stealth as possible .
    If it`s no more than 73mm then the 68-73 size will do.
    See https://www.empoweredcycles.com/blog...d-drive-motors
      Just found out it is a 73 mm with 2.5 mm spacers on each side of crank . I assume you would have to add 5 mm to width to get proper offset for arms as to acheave original width to clear chain stay. Makes a total of 78 mm width. Confused on which size to order . Would I need a 92 mm ?
        The BBSHD 68mm has 68mms of shaft and then 20mms of thread. This motor should be ok. The next motor is 100mm
