Speedo usually shows 0 mph, sometimes shows proper speed when pedaling.
    Bike with BBS02, 56v Luna Battery, Color display. First Speedo stopped working a while back. Tore bike down in order to re-route cabling, and bought a new speedo. All is fine, except, often it says ZERO mph. For instance, a 4.9 mile ride (calculated with Strava) reported as a 4.0 mile ride (calculated by Ca Ebike color display), which is mostly downhill, and possibly not pedalling. Speedo is very close to magnet, so I doubt that's the specific issue (also, not getting 21H speedo error). Have searched, but can't seem to find anyone with this specific issue. Since this has started, I've actually torn it all down, added a newer Luna color display (new model), and tested with other speedos, I still get the same result. Could it be wiring inside of the motor? Do I need to look into replacing the cable from motor to speedo?
    Maybe something went wrong in the controller itself when original speedo failed, try replace the controller?
      Drat, that's quite the expensive troubleshooting step. Thanks for the suggestion though. You could be correct.
