How does the power switch work on the 60a 36~72v bluetooth controller?
    I just purchased this controller to use on something other than an cyclone motor, I have wired up other controllers before, but the Hall Sensor wire bunch on this one threw me. I'm used to to seeing red, black, yellow, green, blue(5 wires). This has an extra wire, half yellow half green, and the red wire is labeled power switch. I'm used to seeing a separate two wire group for power.
    How do I turn this controller on?
    The red wire has negative voltage so I trhink I need to feed it something, I'm just not sure what.
    Thanks for any help you can give.​​​​
