New to this, need sugestions for front hub kit.
    So much information I am overwhelmed,
    I have a Rans Stratus LE recumbent bicycle that I would like to install a 20 inch front hub motor on, I would like something simple to install and use but looking for a quality setup.
    Just had pacemaker surgery and need a little help to get me back in shape, I am leaning towards a gear drive hub for the free wheel aspect but I am new to this and have no experience other than what I have read on the forum.
    Thank you..
    I am just now trying to install a front mac motor from Luna in my 20" front Ryan Recumbent. Very similar. I am trying to figure out how to compensate for the motor being off-center. Do I just force washers on the non-disc brake side? By the way, I had to grind the dropouts much larger to fit the axle.
      Hi lentuk,
      And welcome to the forum!
      Lots of things to take into account... My experience is solely piloting a Magic Pie 5 rear hub motor. But I just wanted to say that if your interested in a geared hub, regeneration is not doable with that type.(If that's important to you)
      I'd also recommend a lighter motor on your type of bike especially in the front. Like the magic Pie Edge if you'd want a Direct Drive. These Pie kits are pretty good, with an internal controller, just add battery and perhaps display.
      Hi Stu!
      Hub motors need to be dished when mounted into the rim. Plenty of information about on this...
      I just had my rear wheel driven Luna motor laced into my wheel and now it does not fit centrally with less than 1/4 inch on the non drive side. Is this going
      I assume that you have a steel front fork and are planning on using two torque arms, one on each side of that monster! :-)
