Does 52v Mighty Mini Cube Samsung Ebike Battery Pack need a BMS?
    It doesn't look like the 52V Mighty Mini Cube incorporates a BMS. Can you explain how the charging works? I thought that each cell needed to be monitored during charging but it looks like the charger doesn't have this capability.
    The product description page includes all of the text below:
    • 30 amp continuous 50amp maximum BMS
    "every ingredient in this pack is top shelf from the cells, to the BMS, to the cell holders "
    Smart Battery
    Luna Cycles builds its packs with the finest BMS (battery management system) available so that you can plug in your battery and not worry about over charging, over heating or running its voltage down too low. Your cells are automatically balanced by the internal BMS in the battery. Our BMS includes such features as temperature over heat protection and advanced cell balancing. These features not only get the maximum performance out of your BMS they also keep your battery from getting to low, charging too high, or getting too hot and will automatically shut off your pack if it senses something is wrong. (read our article on BMS)
      Oh great. Thanks. I didn't see that.
