Luna Fixed Stealth - What is motor brand?
    Is this motor based on the TSDZ2? Or something else?
    Would also like to know
      This photo shows the LH side of the bike.
      https://electrek.co/2019/05/13/lunas...electric-bike/
      Definitely not a TSDZ2. More like a hub motor inside of a dedicated bottom bracket. 36V,250Wh=7Ah. So it's an assisted bicycle. You will be doing a lot of pedaling with this one. But Fixie style with 3 speed IGH, Gates belt drive and disc brakes is a pretty cool bike without the motor. Not a lot of range there under it's own power. if you want to arrive at your commute a little fresher, and can charge it up for the ride home it would be in it's element.
        The webpage says it is a Bofeili, so I guess that would be Suzhou Bofeili Electric Technology Co. Likely their BFLEM36 motor.
