Chain derailing. 46T to 36T bling ring.
    Hi, I have a Luna built KHS Alite 50 bike with a BBSHD
    Motor. I had the Lekkie 46T Bling Ring on the front and just replaced it with a 36T Lekkie bling ring. On the rear I have a SRAM 8 ring cassette with 11T-30T. I can’t use 1st and second gear with the 36T Bling ring because there isn’t enough offset to align the chain properly. Is there a different cassette I can buy that will give me the alignment that I need along with more teeth on each ring to give me more torque for climbing hills?
    Thanks!
    Originally posted by Slipka26 View Post
    Hi, I have a Luna built KHS Alite 50 bike with a BBSHD Motor. I had the Lekkie 46T Bling Ring on the front and just replaced it with a 36T Lekkie bling ring.
    Oh well, so much for your chain line!
    Yup ...
    Nope ...
    ... along with more teeth on each ring to give me more torque for climbing hills
    Yes, a Shimano / Sunrace / SRAM 8-speed cassette with a 34 tooth low gear or maybe one of the obscure brand, mega-range cassettes with a derailleur hanger. Combining one of these with a Luna Eclipse 42 tooth chainring is probably the best you can do.
    BBSHD/BBS02B builds: 1 2 3 4 5 6
      SunRace has an 11-40t 8-speed that would give you more low end with the 42t ring than your 11-30t on the 32t ring while leaving your top end the same as with the 42t ring - best of both!
