BBSHD repair shop in SF Valley in Los Angeles
    I bought a Luna bike a year plus ago and have suddenly been having problems with motor. It would go fine for minutes then shut down for no reason with error codes relating to speedometer. Tried messing with cables and display but have made matters worse. Looking for a shop that knows how to work on these motors. Any suggestions welcome as most (at least the 4-5 I called) do not know how to work on these. Luna being somewhat local seemed like a good place to start looking for help. Thanks.
    http://www.bikecraze.com/
    Likely they can do it.
    Speedo error is typically due to the magnet and/or sensor needing to be repositioned. TBH it is pretty easy to address: https://electricbike.com/forum/forum...x-speed-sensor
      Magnet and sensor is what I started with then snapped the sensor from it's position on the frame... Not sure if Anaheim might be a bit far to get this done. Was hoping that in a city this big, there might be a closer place. Thanks for quick response. Does Luna do any repairs?
        Yeah that plastic can get a bit brittle after a while in the sun, I broke my own sensor mount bracket not too long ago. Thankfully we just got more sensors in stock which includes that bracket
        https://lunacycle.com/parts/bafang-p...speedo-magnet/
        In the meantime, depending on the controller revision you may be able to still ride the bike by going into the display settings and turning the auto-off feature from "5 minutes" to "disabled". It is hit or miss with a bike from that timeframe but might be worth a shot.
        Sorry no Luna does not do repairs we are an e-commerce company. Here are some other companies that may be able to assist
        https://www.reddit.com/r/ebikes/wiki...nd_maintenance
