Buzzraw x frame builds?
    I saw back in 2018 someone asked when they could expect to see the full suspension X frame kits available for builds and you mentioned it shouldn’t be an issue. Is it possible to get a banana build on the X frame currently? Would love some suspension for the commute. Thanks again
    After testing turns out they changed the frame so it's not possible. Maybe with the front fork it can work however in order to retrofit the existing frames with one of their suspension forks you would need to rebuild the wheel with a new hub
