Pas sensor wiring issue
    Hi i have cyclone 3000w mid drive motor for my bike. I install pas sensor and i connected its wires. So from controller three wires are coming i.e. red, black and blue. And from sensor i got three wires i.e brown, black and yellow. I connected red to brown, black to black and blue to yellow. Sensor's indicator is blinking when magnetic disk is moving but motor is not activating. What can be the reason ???? I swapped the wires but still no result.
    Hi Dippin,
    And welcome to the forum! :-)
    Seems manufactures have a skewed sense of humor when determining PAS sensor wiring colors...
    From your description of your wiring connections and with typical controller wiring colors, it would seem correct. And the blinking light is a good sign.
    I know that the standard cyclone controller requires that you also connect the PAS activate wires as seen in the lower left of the diagram. Any chance you have one of those?
    If not please give details on your PAS sensor and mounting location/direction of rotation, and controller particulars for more accurate suggestions.
    Regards,
    T.C.
      I have a Franken e-bike that has no PAS sensor activated on it. I found the Brown Yellow Black wire to hook up the PAS sensor I bought to and the light lights up upon pedaling in one direction. I will send a picture of the leftover wires tonight to designate the PAS activation wires , or is there a standard PAS activation wire set.
        Pictures won’t load wires left are as follows
        Black/Blue
        Red/White/Black
        Yellow/Black
        Yellow/Black
          With the PAS sensor plugs into the brown black yellow
          • I then jumped the blue black & spun the peddle and nothing
          • I plugged the yellow/black into blue/black & spun peddle and
          • The other yellow/black is hot, pos and neg .-
            I seem to be getting somewhere while riding the bike after a couple 10th of a mile the PA window says Cruise and powers the bike at a moderate pace. When I try to change the PA level cruise disappears and no assist. Does PS need to be turned on in the controller somehow ?
