Any idea when the 52 volt, 17 ah packs will be back in stock? I should have purchased it when it was available. Thanks Hunter
Luna Restock Questions Answered Summer 2021
paxtana any possibility of restock on the following or can you point me in the right direction? I've snapped mine and cant find one anywhere so I'm dead in the water. RST isn't responding. Please help!
Yeah RST never seems to respond to anyone unfortunately. We have had a shipment from their dealer that was supposed to arrive over a month ago but their new ETA is still another month away.
Your best bet is one of the other Surron dealers. Try this https://www.surronsouth.co.uk/index....product_id=142
You might check with Australia Sur Ron. If in stock they are $7 US
Last week had an X1 in cart. wasn't able to checkout due to PayPal issues. Once I fixed the problem my cart was emptied and they were sold out. Could I be placed on standby or notification list for size large please?Last edited by Chrisac85; 10-29-2020, 05:30 AM.
Any idea when the BAFANG Half Twist Throttle will be back in stock? I assume that will work on my X-1? Also is there a display similar to the X-1, 860c, that would work on my Sur-Ron? Thanks, Bob
Not sure on throttles, if I had to guess I would think it would not work same but if you pull the original and check the connector it should give a good indication of compatibility. The ones on the site use round higo connectors and seems like most of the connectors on the X1 use the more triangular type. If our shop installed standard throttles with some type of adapter then it would be likely those other bafang throttles would work.
There is not currently a display similar to 860c for Surron, but that may change in the future.
paxtana in case you have anybody else that finds themself in the same situation with the rst axle, send them to these guys: https://risseracing.com/store/produc...roducts_id=668
They made a new axle identical to OEM except the axle screws into the fork and the secondary capture nut then screws into the axle not the other way around like stock. It is 100x better
Yeah Risse is the RST dealer for USA. They are who we have been spending months trying to source the stock ones through, since Surron takes forever. Turns out Risse takes forever as well though. We have sold their non-reverse threaded axles in the past on the site, but there was some concern that since they are not cross compatible with the original axles, someone would end up trying to combine parts from each axle type and complaining about it.
I posted this on a different thread not knowing this one existed. Do you have an estimated ship date for the small batch of large X-1's that were ordered in October with an early November ship date?
Following up on the ability to order a large X1...
Not holding you to it in any way shape or form, but best guess how far out would a large X1 order would be? I am considering ordering a surron for the time being if the large is a ways out. But if the large is available to order in like 4 weeks or something I’ll probably wait. The small X1 is already on order for the wife and she will leave me in the dust until I get my ebike
