Hello, any estimate for restock on Wolf magnet mount? Would like an extra one to be able to easily transfer battery from bike to a different spot.
Luna Restock Questions Answered Summer 2023
As far as I know in-house battery production is likely to be discontinued if it has not already, so I don't believe there will be more magnet mounts available in the future. If you need a magnet mount you can likely make one though, the V1 mount used only off the shelf components https://lunacycle.com/extra-luna-wol...unting-magnet/
That's pretty much just a big strong neodymium magnet with a machine screw holding it in place. The width between the mount rails on the underside of your Wolf is around what the diameter of the magnet should be (maybe a little less just so it is not a tight fit)
Asking again. 500c Mighty Mini display restocking estimate please.
Originally posted by GotTaGo View PostI need a replacement BBSHD display that is smaller than the units that are currently available. Will and when will the Eggrider V2 or the 500c Mighty Mini be available? Or, can you suggest an optional display that isn’t as big as the DPC units.
Any idea on a BBS02 restock? I have a 1984 Vitus 979 road bike - the first bike I ever built in 1984 - that I want to electrify as a project. I think I've lost enough weight I can ride a bike with 700x28C tires again :-)
Any estimate on when there will be new Wolf batteries in stock? I've got one with a bad BMS (cuts off power long before it should) and need to order a new one.
Sorry, this is unlikely to be restocked at this time. 73Eldo is correct in that one of the main issues is supply chain, requiring a total redesign to do it proper. We did do that for our custom controllers, but for our batteries it is too much liability to focus on.
Hi Nick,
Since we have an official answer here about the Wolf, there is another compact battery pack manufacturer now in Utah which is creating the new battery "Wedge" pack which is very similar in overall dimensions to the Wolf and marketed by the well known " L " Brand.
