My ignition switch I believe has started to wear out. It some times cuts out when the key is switched on and I have to turn it back slightly to turn the bike on. Will you ever be stocked the igntion switch/battery door replacement components in the future? I'd rather not import them from the UK.
Sur Ron Ignition key switch
