Shimano Deore M615 Hydraulic Brake Set with Bafang Ebrake cut off
    Curious...how are the levers integrated into the Bafang harness? Is this through an OEM switch?
    Same as the OEM brake levers, with a Higo plug into the harness.
      I have a 2005 Gary Fisher Big Sur, Hayes 9 hydraulic brakes with 160 mm rotors. I want to buy the Shimano Deore M615 Hydraulic Brake Set with Bafang Ebrake cut off set.
      Do I need the post adapters as well? And would an upgrade to 180mm rotors be a simple bolt on then?
      Thanks in advance!
