Luna Cycle Product Re-stock Requests
When is the xt60 female to barrel adapter coming back in stock? You wouldn’t happen to have an extra 52v charger for the wolf laying around the shop for sale would you? I just realized my 48v charger is not charging my battery to the fullest, thx
Not too sure on the xt60-F to barrel, but we do have the barrel itself if you want to bolt it on in place of an xt60 or even make your own xt60 to barrel adapter using the xt60 connectors. https://lunacycle.com/solderless-barrel-connector/
Originally posted by frijoles24 View Posthttps://lunacycle.com/asi-bac-800-co...r-72v-version/
any ideas for the 72v?
Update on this?
https://lunacycle.com/72v-triangle-panasonic-GA-10-5ah/
Either of the two are fine, do you know when they'll be back in stock? preferably the first one
Any idea when you might get lights back in stock? https://lunacycle.com/extras/lights/...t-extra-power/
Same with the rear red light. Thanks!
Time change means it's dark a lot sooner :)
60A 36-72V Controller availabilty
Could you give me a rough schedule please, to know when it will be available? Just to understand, if it's worthwhile waiting for. Thx
You mention you will be carrying different chainring sizes for this Luna Eclipse product you sell:
https://lunacycle.com/luna-eclipse-c...for-the-bbshd/
"We will be offering a full range from 40T to 56T chainrings which you can change out."
Can you give us a solid ETA when these other sizes will be available? Are these sizes going to be made: 40T 42T 44T 46T and what size 50T rings will you carry? 50T 52T 54T 56T When available?
Please consider offering a discount if one buys a two or three chainring pack of different sizes with the Eclipse face. Thanks!Last edited by Volts-n-Current; 11-28-2018, 03:50 PM.
The 40t is here https://lunacycle.com/luna-eclipse-4...ece-chainring/
The 42t sprocket option will be on that page as soon as we make more sprockets, maybe 3-4 weeks.
Can't comment on unreleased products but that's what we have in the lineup right now. 48, 42, and 40. 40 is way different offset by the way, just in case that's not clear. We also have various other rings in parts section depending on stock https://lunacycle.com/bbshd-parts/
Luna Cycle Truck Cargo eBike shown here: https://www.youtube.com/watch?v=C2MW71GNd2I
Are these frames available from the frame builder? I see you don't list this product anymore. Where can these frames/bikes be purchased now?
Do you plan to restock these again? Is there any tech specs or threads about this frame and/or bike? Are there any used, demos, or cosmetic damaged frames that are leftover from your old stock?
Thanks.
Sure, it's called the sport utility bike from cycletruck. http://www.cycletrucks.com/
I do not have info on restock for this. Possible at some point but probably not within the timeframe you would want it by.
When are you going to be getting the battery shrinkwrap back in stock. The smaller sizes. https://lunacycle.com/shrink-wrap-tu...pack-per-foot/
Hi there, on the website right now it looks like you are out of https://lunacycle.com/bafang-bbs02-750w-middrive-kit/
All possible configurations are saying currently unavailable, any idea when these will be back in stock? Thanks
Hey thanks, the reason it's not working is: "The option selected for Optional Display Upgrades is currently unavailable." You were right, I hadn't selected anything for the optional display section but that's because I don't want an upgraded display. Perhaps an issue with the site requiring this?
The default display is out of stock so you have to choose one of the displays to order it right now.Last edited by HIGHVOLTAGE; 12-05-2018, 11:00 AM.
My BBSHD throttle just sheared off. I had the cheaper $15 thumb throttle kind. I saw the other version of the $20 thumb throttle and wanted to order one. Any idea when they'll be back in stock? Or any other higher quality thumb throttles?
Thanks!
I noticed the BBSHD 68 is showing back in stock. Are they actually in stock to be picked up Monday or are they coming into stock shortly
Typically if you are local you'll want to order with local pickup option then email support@lunacycle.com your order# so we can ensure the item is ready to be picked up. Pickups are not doable on mondays, only tues-fri.
