Luna Cycle Product Re-stock Requests
    Are BBSHD programming cables coming back anytime soon?
      Are there programming cables available anywhere?
        BMSBattery also sell them but be careful about shipping costs.
        I am told the ones that Golden Motor sell for the MagicPie are the same...but no personal experience so can't verify this.
          We have a thread on how to make your own. http://electricbike.com/forum/forum/...ming-cable-diy
            Looking forward to purchasing a Magic Pie programming cable! Spring is just around the corner! :-)
              Bump? I'm still wondering if/when these will be available...
                We are waiting on Bafang. Given the significant language barrier it's always kind of a gamble what they send but if they sent what we wanted we should be restocked within a few weeks.
                  Luna Cyclone mini deluxe kit
                  and also the CNC'ed mounts sold separately
                    Deluxe is not coming back that's why there is a redirect on the page. We're not getting more kelly controllers. Maybe at some point we will bring it back with ASI but that's not up to me.
                  • Sebz
                    Sebz commented
                    That is why I suggested to sell the brackets alone just like we do with the Cyclone 3D/2D mounts.
                    And the Mini is already sold with a optionnal ASI... so I suggesting just a bracket option.
                  Cyclone 3000w kit and a higher AH 72v battery, also it would be nice if you include the newest mounting system with the kit which is currently being sold separate. It would just make more sense than buying the kit with an ok mount and then having to buy the more proper mount later on.
                    looking for the eclipse chainring in 42t size. also chainring spacers for eclipse. any idea when they will be back in stock?
                    thanks
                      You mean for chainring spacers? Yeah they auto-hide. We do have the lekkie ones. https://lunacycle.com/lekkie-bling-ring-spacers-bbs02/
                    • LordBinks
                      LordBinks commented
                      will the lekkie spacer work in combination with the others? i only need one more as i was able to order four of the eclipse version and i need 5
                      Yeah a spacer's a spacer. Long as it's for BBSHD it'll work. (i know the url says for bbs02 but i did link you to the hd, you're fine)
                    Will you be getting more of the following battery pack?
                    52V PANASONIC GA 10 AH PERFORMANCE + LONG RANGE
                    This can be used on a townie ladies step thru I understand.
                      Hi yes we will. Probably a month though, give or take.
                    Hi guys,
                    was wondering when the 4 season 500 or 1000 khs bikes were going to be in stock.
                    also, real quick, would a med. 17 in. bike fit a 5’10 person?
                    thanks!
                      Hi Singulis, just waiting on KHS to come out with the 2018 models so we can get started. All 2017 frames are long gone.
                      Check the specs on the listing for links to geometry showing standover height.
                    Any ETA on the 42T Luna Eclipse? Center piece and the chainring? I'm doing another BBSHD build and I need more offset than the 42T Lekkie.
                    On my last one, I needed 8.3mm of spacers to fit a 120mm BBSHD to a 100mm BB'd Chumba Ursa Major large titanium frame (its branded differently by the mfr for Chumba if you saw it on FEB).
                    Now I am building on a Motobecane Lurch frame I got second hand, and I needed 17mm of spacers for my other 120mm motor, to get the secondary housing away from the chainstay. If I can get 4-5mm back towards the frame it should help a lot on a bike that is going to see use on the 36T inner cog if I can get it there.
                    • Sebz
                      Sebz commented
                      Hi, probably a week or two I guess,
                    • MoneyPit
                      MoneyPit commented
                      Kewl should give me time to get another paycheck in the bank :-)
                    Looking for a Black or Silver 42 tooth Eclipse chain ring. The website says you are out of every color in both 42 and 48 tooth. What's happening? Is there an inventory glitch? If no glitch, when would you guess you would have 42 tooth Black or Silver Eclipse chain rings in again?
                    and No, I don't want a spacer, I need to move the ring closer to the centerline of the bike.
                    Thanks -
                      No inventory glitch. Just entering the Spring season so things are starting to ramp up and stock is starting to move quickly. We'll have them back soon.
                    Just saw the sur-ron pedal kit install option was taken off the website. When will they be available again ?
                      Likely in the next shipment, probably six weeks.
