Luna Cycle NEW product requests
    Ooo... how about a Fusion replacement pack for the V1 Apocalypse (52 volt), for when it comes time to replace my battery? Don't want to just replace the scoot, due to the V1 no longer being made.
      The Apollo !
        I may be interested in buying the apocalypse scooter soon, but I'm hesitant as I am wondering if there will be a V3 version coming out sometime this year.
        Any word of a potential version upgrade coming out soon?
          Will you be re-stocking the BBSO2 mid-drives and the 52v mini-cube batteries anytime soon?
            Yes, these are very popular sellers so I don't think they'll be going away anytime soon.
          #50
          Paco, at Cyclone-TW has just received an order of 1 meter long extension cables, which will work with all Cyclone motors employing the waterproof-cable. This item will allow users the ability to position their controllers further from their motors--further out of the splash-zones; further out of the rain.
          For cargo bikes, for recumbent bikes and trikes, for pedicabs, and the like, I think this would be a big plus.
          But for people who want to go "mudding" -- or just splash through that stream that is probably borderline too-deep; it would let them feel freer to go wilder--without risking their (sometimes quite) costly controllers.
          I don't work for Luna, I don't work for Cyclone. I just want to let you all know what's out there.
          Though I've not held them in my hands to compare, I do believe I've seen this same waterproof-cable used on a variety of other brands of motors currently on the market; not just those from Cyclone. If that's so, this extension cord might be a seriously useful item for a company like Luna to consider stocking.
          Anyways, there you go.
          Paco sent me a pic of them, so I'm passing that along here also.
          Oh, and yeah--for sure I'm gonna order one--I want my controller out of the elements too!
          Take care, everybody!
          tklop
            I'm in the same boat. I put in an order for the Apocalypse V2, but ended up cancelling it. It doesn't make sense to buy V2 if V3 is coming soon for a similar price. I can imagine it's even more polished and hopefully having MPH readout and more control over LVC (premature cut out due to voltage sag under high load). Please let us know some details. If you tell me it's going to be 6 months, I'll just buy the V2. If it's around the corner, I'll wait.
              I would like a 52 volt 28 amp hour battery that weighs 3 pounds or less. There is probably a Nobel prize if you can do it.
                How about magnetic mounting plates and magnets for shark and dolphin cradles in order to make them swappable with the wolf's - I can't consider a battery that can't be swapped and I have too much legacy with dolphins and sharks...
                  I'm thinking a plate that could be screwed onto the shark/dolphin mounting cradle. Throw an XT90 on the cradle and then just treat the cradle and battery as an assembly that can be unplugged and moved like the wolf. It'd be thicker with the magnets and the cradle but it would essentially turn a shark/dolphin into the same mount as the wolf and allow them to swap easily. I dunno - I haven't seen the wolf up close and personal but I can't readily consider one seeing as I've got four or five sharks and dolphins.
                • xcnick
                  xcnick commented
                  Didn't think of it your way because I am always making it thinner. I will get a couple of pics.
                • xcnick
                  xcnick commented
                  Velcro the mounting plate and all using the magnetes just a flat surface. If you don't need a battery I would wait. Rumor has it that their next battery is 2170s, 52 volt, 28amp hour, at 3lbs. Mailmans here, gotta go.
                #54
                Stupid pics, but Wolf over Shark you see a rail in the way. It is only there to stay centered on the magnets. A grinder might be in your tool box. Shark over wolf magnets is close enough I would happily mount it with 200 mph tape if I had a connector. (This is a Hailong 3)
                  Need to get some 26" rims for the Mac rear hub motor kit
                    Sur-Ron White Ghost
                      Higher Ah Wolf Packs (or higher Ah batteries using wolf pack tech)
                        New, high capacity batteries in 52V triangle format, to fit where your 14S 7P PF pack will fit. wider, fine. But if you could get 30+ Ah in that form factor, us triangle users would be sorely tempted.....
                          25ah plus hard case triangle with 21700 cells and some sort of down tube mount
                            Love my new Wolf Pack. Need extra magnet sets for other bikes. When may I expect them to be available?
                              Just email us, we can sell a set as a special order
