100% charge voltage.
    I have a Panasonic PF 11.5AH pack.
    Since it was new I have only charged it to 80% capacity. I read that this extends batt. life and I only need 80% for my commute round trip.
    I have about ten 80% charge cycles on it to date.
    Now I want to charge it to 100% for a longer trip I have planned, but it will only charge to 58.7V. Is this normal? or should it reach 59v?
    Thanks for your responses.
    4.2 v/cell x 14 cells = 58.8. As far as I know, you are pretty much there at 58.7
      I'd do a couple of 8 hour charges to make sure all the cells are balanced. Every new pack I get goes through at least 2, 8 hour charges.
        Thanks for the advice. My charger just shut off at 58.7. Do you leave it plugged into the charger even after it's shut down for reaching set voltage?
          Leave it. Plugged in
