I have a Cycle Satiator, purchased last March. Went to hook up to my laptop running Windows 7 and it won't connect because I can't get past downloading the USB driver from Grin's web site. The download file gets into the 'Downloads' folder alright, but when I try to run the install, the file fails at the "extract file".
Anyone else have problem with this and found a remedy. I have an email into Grin support, but nothing back yet. I was doing this last night, so I can give them a bit to respond. Just wanted to check here to see if anyone else had experienced something similar.
When I bring up the Satiator Software Suite and try to connect, the message comes back as "No Com Port found". My 52V shark battery from Luna that was purchased with the BBSHD kit has a charge, but obviously, I want to be able to charge the battery pack after some use and if the Satiator won't work, then I'm in a pickle with big dollars spent and no charging available.
I need to transfer 2 charging profiles I created, one at 100% and the other at 90%.
Any guidance would be most appreciated.
Dave
Dave
