Show us your custom battery and or box here
    Please document you custom battery builds and cases here.
    This will help other forum members who may have a frame that may need a customized battery or case.
    Ok Guys I will start this off.
    Heres mine.
    A piece of aluminium which i used to hold my pack. I bolted it to the water bottle holes.
    The packs was wrapped in tap to ensure a tight fit.
    To finish it off I then covered the pack in carbon fibre wrap.
    Another option if I was unable to slide my battery into this piece of aluminium would have been to first bolt on a flat piece of plate to the bottle holder holes then slide the battery over this plate and then bolt both together.
      I needed a really tough battery box that fit tightly in my panniers (so as to maximize space). I bought a lot of aluminum bar and angle aluminum from Online Metals. I used a bandsaw to cut the aluminum, and I connected it all with rivets.
      The box is very strong. A car ran right into my panniers with one of these inside, and the battery box was not damaged. I have also gone down hard on the panniers on two occasions, and the boxes were never damaged. However, in all three of the above cases, the panniers were torn.
ID:	24840 Click image for larger version
ID:	24841 Click image for larger version
ID:	24842 Click image for larger version
ID:	24843 Click image for larger version
      • Max-Ebike
        Max-Ebike commented
        You need to mass produce these! Nice work!
      The battery boxes are bolted to a steel strap welded into the bike frame using 1/4" Grade 8 hardware. I drilled holes in the pannier to allow the bolts to pass through.
ID:	24846 Click image for larger version
ID:	24847 Click image for larger version
        That's pretty cool Commuter; it looks like you got center of gravity real low.
        Curious if you feel a sway or pull on corners from inertia of battery packs.
        I ask because when I mounted a shark on top of pannier rack I experienced that.
          The weight is equal on either side, so there is no lateral sway. The few times that I have carried an extra battery (which fills the panniers at that point), I could definitely feel the extra 20 lbs. in the top of the panniers.
          I weigh 285 lbs. and the bike weighs 90 lbs., so adding an extra 20 lb. battery is only adding 5.33% more weight.
          I think it rides better with only one battery (i.e. a 10 lb. 36V battery at the bottom of each pannier).
          Another 10 lbs. in the top half of each pannier definitely makes it feel top heavy.
