Shark pack charged with timer
    I have a luna 52v 13.5ah Shark Pack and the luna 52v Mini Charger with 3 Position Toggle. I would like to know if plugging the charger into a timer would discharge or damage the battery in any way?
    Should be OK. Mine are not Shark packs, but I have been using this one for years with no problem.
      The leakage current for the current generation of charges is of the same order of magnitude as a BMS. Overnight or even a few weeks will be fine :) A couple of months and you will run into problems :(
