Mounting carbon shark pack inverted
  • Mounting carbon shark pack inverted
    I have a 2012 specialized camber comp 29er and I really want to mount my 52v carbon shark on the downturn.
    The only way to do this was to spin the rear shock 180 degrees so the controls are facing up and mount the battery on its top on the down tube.
    My question is it safe to mount the battery on its top? Planning on using zip ties and hot glue.
    I will also also have to cut the aluminum piece from the mount in half to make it fit.
    The other option is put the battery on the top tube like a gas tank.
    Thabks in advance for any help you can give.
