Samsung 50E capacity test - 5000mAh or not?
    Samsung INR21700-50E is a 21700 size cell which is being sold as 5000mAh one while in its official datasheet the capacity is mentioned as "Min. 4900mAh" and there is absolutely no "5000mAh" mention anywhere.
    I've followed all the prescriptions of the IEC61960-2003 standard concerning battery's capacity measurement. Before each discharging cycle each battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hrs pause. The environment temperature was 23.0-24.5°C. To be sure in results i've done each test minimum twice (usually 3-4 times).
    The cell is marked as INR21700-50E SAMSUNG SDI 2I75 which means that the production date is 05 Jul 2018.
    The main specs from Samsung 50E datasheet:
    Capacity (min): 4900mAh
    Nominal voltage: 3.6V
    Standard charge current: 2.45A (0.5C)
    Charge cut-off current: 98mA (0.02C)
    Max charge current: 4.9A (1C)
    Charge end voltage: 4.2V
    Max. continuous discharge current: 9.8A (2C)
    AC impedance at 1KHz: ≤35mΩ
    Max weight: 69g
    Measured DC IR at 4.9A in fully charged condition was 26.5±0.5mΩ
    Measured weight of the tested cell was 68.8g
    Capacity test results:
    At 0.2C (0.98A) discharge 50E's capacity doesn't reach 5000mAh and is slightly higher than 4950mAh which makes me think that 50E must be classified as a 4900mAh cell rather than a 5000mAh one. All the curves look very nice and smooth. At 10A 50E's capacity is more than 4700mAh which is a good result for a 4900mAh cell.
    50E is a slightly better cell compared to 48G but the difference is hardly noticeable but bear in mind that 48G's standard charge current is much lower than that of 50E - 1.44A vs 2.45A.
