Samsung 20S - high drain 18650 Li-ion cell's capacity test
    Hi guys! Samsung INR18650-20S is a 2000mAh Li-ion cell of 18650 size which supports continuous discharge at up to 30A.
    I've followed all the prescriptions of the IEC61960-2003 standard concerning battery's capacity measurement. Before each discharging cycle each battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hrs pause. The environment temperature was 23.0-24.5°C. To be sure in results i've done each test minimum twice (usually 3-4 times).
    The cell is marked as INR18650-20S SAMSUNG SDI 3 1IA1 which means that the production date is 01 Oct 2018.
    The main specs from Samsung 20S datasheet:
    Capacity (min.): 2000mAh
    Nominal voltage: 3.6V
    Standard charge current: 1.0A (0.5C)
    Rapid charge current: 4.0A (2C)
    Charge cut-off current: 100mA (0.05C)
    Charge end voltage: 4.20V
    Max. cont. discharge current: 30A (15C)
    AC impedance at 1KHz: ≤15mΩ
    Max. weight: 48g
    Measured initial DC IR at 2A in fully charged condition was 11±1mΩ
    Measured weight of the tested cell was 46.25g
    Capacity test results:
    At 0.2C (or 0.40A) discharge Samsung 20S's capacity is 2165mAh - noticeably higher than the 2000mAh declared and it plays around 2000mAh all the way up to 20A but the energy, of course, decreases. Curves are flawless, without voltage drops and recovers.
    Capacity tests showed that Samsung 20S is a great high drain cell and there is nothing to add.
    Could you advise me? I have a BBSHD and run a stock supplied battery from bafangusadirect. I want to do another conversion and found that DHGATE.com has several 48v 17ah 30a bms, all with 18650 cells but at many different prices. All with chargers. How can you tell if the cells are OK. Seems like a lot of savings but what is the risk. Is it just a matter of the more you pay the better the cells. take a look if you haven't and share your insights. Thanks. here are two examples. https://www.dhgate.com/product/us-eu...arl|1720640828
    https://www.dhgate.com/product/new-h...arl|2171086851
      Find out what batteries they use in the packs and have them verify it with pictures of the inside of the battery. Then it is easy to find the specs of those batteries.
