Samsung 15M - high drain 18650 cell's capacity test (1.5Ah, 23A)
    Samsung INR18650-15M is a 1500mAh Li-ion cell of 18650 size which supports continuous discharge at up to 23A. It's a direct competitor for two 1500mAh high drain cells from LG i tested earlier - HB4 and HB6.
    I've followed all the prescriptions of the IEC61960-2003 standard concerning battery's capacity measurement. Before each discharging cycle each battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hrs pause. The environment temperature was 23.0-24.5°C. To be sure in results i've done each test minimum twice (usually 3-4 times).
    The cell is marked as INR18650-15M M SAMSUNG SDIEM 121.
    The main specs from Samsung 15M datasheet:
    Nominal capacity: 1500mAh
    Minimum capacity: 1450mAh
    Nominal voltage: 3.6V
    Standard charge current: 0.75A (0.5C)
    Maximum charge current: 4A
    Charge cut-off current: 100mA
    Charge end voltage: 4.20V
    Max. continuous discharge current: 23A
    AC impedance at 1KHz: ≤25mΩ
    Max weight: 45g
    Measured initial DC IR at 1.5A in fully charged condition was 13±2mΩ
    Measured weight of the tested cell was 42.16g
    Samsung 15M capacity test results:
    At 0.2C Samsung 15M's capacity was 41mAh higher than the 1500mAh declared and energy was a bit lower than 5.8Wh. At all discharge rates the curves were beautiful and without sags. At 20A discharge 15M's capacity still remained above 1400mAh and energy was above 4.5Wh.
    Now let's compare Samsung 15M with LG HB4 and HB6:
    At 15A:
    LG HB4 (2.5V cut-off): 1402mAh / 4383mWh
    LG HB6 (2.0V cut-off): 1495mAh / 4806mWh
    LG HB6 (2.5V cut-off): 1470mAh / 4748mWh
    Samsung 15M (2.5V): 1428mAh / 4732mWh
    At 20A:
    LG HB4 (2.5V cut-off): 1396mAh / 4238mWh
    LG HB6 (2.0V cut-off): 1506mAh / 4611mWh
    LG HB6 (2.5V cut-off): 1472mAh / 4534mWh
    Samsung 15M (2.5V): 1415mAh / 4555mWh
    LG HB6 takes the cup not only at 2.0V but also at 2.5V cut-off. Only at 20A rate and 2.5V cut-off its energy is lower than 15M's. Nevertheless 15M's curves i liked more and its average voltage was higher at all rates.
