Sony VTC6 - a 3000mAh/30A monster in 18650 size
    Sony US18650VTC6 (or just VTC6) is a high drain 18650 size Li-ion cell which supports discharge rate up to 15A if no temperature control is used and up to 30A with 80°C temperature cut.
    I've followed all the prescriptions of the IEC61960-2003 standard concerning battery's capacity measurement. Before each discharging cycle each battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hrs pause. The environment temperature was 23.0-24.5°C. To be sure in results i've done each test minimum twice (usually 3-4 times).
    Sony US18650VTC6
    The cell is marked as
    SE US18650VTC6 C6
    G 0400743YF20U
    The main specifications from Sony VTC6 datasheet:
    Rated capacity: 3000mAh
    Nominal capacity: 3120mAh
    Nominal voltage: 3.6V
    Standard charge current: 3A (1C)
    Charge end voltage: 4.20V
    Max charge current: 5A
    Max continuous discharge current: 15A (5C) / 30A (10C) with 80°C temperature cut
    Discharge cut-off voltage: 2.0V / 2.5V
    AC impedance at 1KHz: 8-18mΩ
    Weight: 46.6±1.5g
    The measured DC IR of fully charged cell at 3000mA was 15±1mΩ (measured using EB Tester Software).
    My cell's weight was 46.83g
    Capacity test results
    High current curves are excellent, there is nothing to say. The only thing which seems strange to me is the 2.0V discharge cut-off voltage Sony uses at 0.2C. Why 2.0V? I think it's just to push the nominal capacity a bit higher because nobody gonna use VTC6 at 0.6A discharge rate. I can't find any other explanation for this.
