Samsung 25R - high drain 18650 Li-ion cell's capacity test
    Samsung INR18650-25R is a 2500mAh Li-ion cell of 18650 size which supports continuous discharge at up to 20A.
    I've followed all the prescriptions of the IEC61960-2003 standard concerning battery's capacity measurement. Before each discharging cycle each battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hrs pause. The environment temperature was 23.0-24.5°C. To be sure in results i've done each test minimum twice (usually 3-4 times).
    The cell is marked as INR18650-25R SAMSUNG SDI 5 2H62 which means that the production date is 02 Jun 2017.
    The main specs from Samsung 20S datasheet:
    Nominal capacity: 2500mAh
    Nominal voltage: 3.6V
    Standard charge current: 1.25A (0.5C)
    Maximum charge current: 4A
    Charge cut-off current: 100mA
    Charge end voltage: 4.20V
    Max. continuous discharge current: 20A (8C)
    AC impedance at 1KHz: ≤18mΩ
    Max weight: 45g
    Measured initial DC IR at 2.5A in fully charged condition was 14.8±1.2mΩ
    Measured weight of the tested cell was 43.59g
    Capacity test results:
    At 0.2C / 0.5A 25R's capacity was noticeably higher than the 2500mAh declared which is good, but this cell is meant to be discharged at much higher currents. All the way from 5 to 20A the capacity was playing around 2450mAh and never went below 2400mAh! The energy at 20A was 7.83Wh and the curve looks excellent! The verdict - 25R is a good choice if you're looking for a 20A cell.
