4.35V LG E1 - capacity tests at 4.35V and 4.20V
    I've previously tested Sanyo UR18650ZTA and this time i've got anoother 4.35V cell - LG E1.
    I've followed all the prescriptions of the IEC61960-2003 standard concerning battery's capacity measurement. Before each discharging cycle each battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hrs pause. The environment temperature was 23.0-24.5°C. To be sure in results i've done each test minimum twice (usually 3-4 times).
    LG ICR18650 E1
    The cell is marked as LGABE11865 0247I048AB.
    The main specs from LG E1 datasheet:
    Nominal energy: 12.0Wh
    Minimum energy: 11.6Wh
    Nominal voltage: 3.75V
    Standard charge current: 0.93A (0.3C)
    Maximum charge current: 1.55A (0.5C)
    Charge cut-off current: 50mA (100mA used)
    Charge end voltage: 4.35V
    Max. continuous discharge current: 4.65A (1.5C)
    Discharge cut-off voltage: 2.75V
    AC impedance at 1KHz: ≤70mΩ
    Max weight: 49g
    Measured initial DC IR at 3.1A in fully charged condition was 56±3mΩ
    Measured weight of the tested cell was 47.52g
    Capacity test results
    At 4.35V charge:
    The nominal energy at 0.2C doesn't reach 12Wh declared and the capacity is a bit higher than 3000mAh. Look at the 5A curve - it's really a heavy load for this guy. I'd not discharge it at more than 2A.
    At 4.20V charge:
    At 4.2V charge the capacity goes down to 2600mAh. The character of curves remains the same, just the numbers get lower.
    COMPARISON
    Let's check how much we lose by using 4.2V charge instead of 4.35V.
    At 0.2C/0.62A:
    Here we lose 13% in capacity and 14% in energy.
    At 2A discharge:
    The same 13 and 14%.
    At 5A:
    We lose 12% in capacity and 13% in energy.
    So in general we lose about 13-14%.
    LG E1 didn't show any fantastic results. It's real capacity appears to be about 3000mAh and 5A discharge seems to be too much for this cell. E1 could be interesting for those who need a high voltage cell for low drain (up to 2A) applications.
    Thanks for the info. Have been riding w my ebike kit for over three years but am a newbie trying to learn about batteries. I don't quite undertsand all this in this post so hopefully your YouTube Channel will have stuff geared for newbies.
