For my first build I chose a carbon fiber fat bike...just like the capable look of it, ever though mostly for the street. A quick narrative:
The donor was a 2014 Salsa Beargrease Carbon.
-Had to grind the motor considerable to fit, but as noted elsewhere there is plenty of material there
-First controller from Bafang was bad - they sent me a replacement gratis
-Biggest aesthetic/practical challenge is routing all the wires!
Parts List:
Overall, very pleased with the result and the suppliers have been very good. This is a great form of transportation (weather permitting).
Parts List:
- Bafang BBSHD motor
- Luna 52V Wolfpack battery
- Luna 500c Display
- Luna 40T alloy chainring
- Surly Open Bar handlebar
- Odi Grips
- Planet Bike Big Buck fenders - front modified to fit my bike
- upgraded front Avid disc to a 203mm
- Arisun Big Smoothy 26 x 4" tires for better rolling on the road
- $20 Amazon headlight, wired directly into battery
- Lezyne Taillight
- Lezyne Brass Bell
- Amazon chain stay mounted kick stand - very sturdy, very convenient
- Ebay plastic fat bike fender cut in half and mounted on downtime to keep muck off battery, etc
- Amazon waterproof small frame bag
- Programmed display for 18" wheel instead of 26" per online suggestions - 35 mph on flat road
- Did not install brake sensors - what's the point?
- Shift sensor not installed....the freewheel and chain are definitely going to be a weakness
- Level 4 and 5 drain the battery very quickly - only seeing about 20 miles per charge at this level
- Have not weighed it, but stock was about 29 lbs..... so I'm guessing around high 40's....
