2016 Cannondale Trail 3 (size L)
68-73mm BBSH with steel 46T sprocket
The install went very smooth. The BB measured out at 73mm after removing the crankset. There was couple mil of protrusion inside the BB from manufacturing that I had to clearance before installing the drive. I used an air die grinder, but a dreamed or even a grinding stone on the end of a drill would have worked fine as very little material needed removed. First test fit had the gear housing resting against the chain stay. I added a .97mm spacer to the drive side (thinnest spacer from the install kit) and that provided a small amount of space between the drive unit and chain stay. The drive locating plate or whatever it's called needed 3 washers under it on each of the 2 bolts. After that I installed the lockring and tightened it with a long spanner wrench that I already had from working on dirt bikes.
The tool is a "Motion Pro T-Stem Nut Wrench" and was perfect to get it good and tight. I used a little low strength locktite on everything and will likely upgrade to medium on the locking when I'm adding another mount.
At this point I've only made a few miles of test rides around town and one trail ride. I still plan to add brake cutouts, a shift sensor and a motor stay that I'm working on. It seems everything is working really good like this and I'm happy with the result. The sprocket is very close to the frame as it should be and the bike is shifting good. With this gearing it has plenty of torque for climbing, top speed feels good, but I have not checked it yet with a gps.
